AW: [Qgis-user] QGIS performance problem
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Tue Sep 1 00:43:08 PDT 2009
Hi Bernt
Yes, please provide me a remote login for debugging. I'm busy today but like to work on the freeze issue tomorrow (Wednesday). I wonder if it is really the same problem or a variation on it.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org im Auftrag von pcreso at pcreso.com
Gesendet: Mo 31.08.2009 20:40
An: Andreas Neumann
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] QGIS performance problem
Thanks Andreas,
Glad to know its not just me as well :-)
Brent
--- On Tue, 9/1/09, Andreas Neumann <a.neumann at carto.net> wrote:
> From: Andreas Neumann <a.neumann at carto.net>
> Subject: Re: [Qgis-user] QGIS performance problem
> To: pcreso at pcreso.com
> Date: Tuesday, September 1, 2009, 6:31 AM
> Hi Brent,
> I have similar behaviour. It happens if polygons with lots
> of vertices
> are involved. Things get even worse if you try to print
> this data with
> high resolution.
> Marco Hugentobler and Jürgen Fischer are already working
> on this issue
> these days. They can also better explain the issues we are
> running into
> - seems to be qt and clipping related when bounding boxes
> of big
> polygons are touched when zooming in or printing on high
> resolutions.
> I am glad to hear that I am not the only person
> experiencing these
> problems - seems to be a real issue.
> Andreas
> wrote:
> > Hi,
> > I have a PostGIS table & shapefile of the New
> Zealand coast (1:50,000)
> > If I open this table it plots in a fraction of a
> second, pretty much as expected, with similar speeds for
> both the shapefile & table.
> > However, if I zoom in, the redraw takes three minutes
> or more.
> > While I'm waiting for the refresh, Qgis is showing
> 100% cpu load, postgres isn't showing at all (top). On an
> AMD dual core 3.2Ghz cpu with 8Gb ram it should not take
> anything like this long, and with earlier versions of Qgis
> (pre 1.0) it was much faster.
> > Performance is similar with both table & shapefile
> data sources, so it does not seem Postgres related.
> > However, plotting lines, points or polygons with tens
> of thousands of features rendered works well, it seems to
> primarily be polygons with many vertices (not even any
> holes) that are the problem.
> > OpenSuse 11.1, Qgis 1.2.0, Postgis table described
> below, only 3 features/records, indexed & vacuumed.
> > Does anyone have any idea what may be the issue?
> > I can provide an ssh login if anyone wants to test
> this for themselves.
> > Thanks,
> >    Brent Wood
>   Table "public.coast_poly"
> >  Column  |
>    Type
>         Modifiers
> >  gid     | integer
>              | not
> null default nextval('coast_poly_gid_seq'::regclass)
> >  id      | bigint
> >  fid     | bigint
> >  name    | character varying(42) |
> >  geom_ll | geometry
> > Indexes:
> >     "coast_poly_pkey" PRIMARY KEY,
> btree (gid)
> >     "coast_poly_geom_ll_gist" gist
> (geom_ll)
> > Check constraints:
> >     "enforce_dims_geom_ll" CHECK
> (ndims(geom_ll) = 2)
> >     "enforce_geotype_geom_ll"
> CHECK (geometrytype(geom_ll) = 'MULTIPOLYGON'::text OR
> geom_ll IS NULL)
> >     "enforce_srid_geom_ll" CHECK
> (srid(geom_ll) = 4326)
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
