AW: [Qgis-user] QGIS performance problem
pcreso at pcreso.com pcreso at pcreso.com
Tue Sep 1 01:31:08 PDT 2009
Hmmm...
It seems that if you set up an account for Marco to try to debug this, then QGIS works perfectly...
Or it could be the OpenSuse system update I just ran, followed by a  reboot which might have fixed the problem.
QGIS is now performing admirably with lines & large/small polygons in PostGIS zooming in & out flawlessly. Both as me & as Marco.
Anyway, Marco has an account here now & I'll leave it there so either
a) it's ready for the next time, or
b) it will ensure there is no next time.
Cheers,
  Brent
--- On Tue, 9/1/09, Hugentobler Marco <marco.hugentobler at karto.baug.ethz.ch> wrote:
> From: Hugentobler Marco <marco.hugentobler at karto.baug.ethz.ch>
> Subject: AW: [Qgis-user] QGIS performance problem
> To: pcreso at pcreso.com, "Andreas Neumann" <a.neumann at carto.net>
> Cc: qgis-user at lists.osgeo.org
> Date: Tuesday, September 1, 2009, 7:43 PM
> Hi Bernt
> Yes, please provide me a remote login for debugging. I'm
> busy today but like to work on the freeze issue tomorrow
> (Wednesday). I wonder if it is really the same problem or a
> variation on it.
> Regards,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org
> im Auftrag von pcreso at pcreso.com
> Gesendet: Mo 31.08.2009 20:40
> An: Andreas Neumann
> Betreff: Re: [Qgis-user] QGIS performance problem
> Thanks Andreas,
> Glad to know its not just me as well :-)
> Brent
> --- On Tue, 9/1/09, Andreas Neumann <a.neumann at carto.net>
> wrote:
> > From: Andreas Neumann <a.neumann at carto.net>
> > Subject: Re: [Qgis-user] QGIS performance problem
> > Date: Tuesday, September 1, 2009, 6:31 AM
> > Hi Brent,
> > I have similar behaviour. It happens if polygons with
> lots
> > of vertices
> > are involved. Things get even worse if you try to
> print
> > this data with
> > high resolution.
> > Marco Hugentobler and Jürgen Fischer are already
> working
> > on this issue
> > these days. They can also better explain the issues we
> are
> > running into
> > - seems to be qt and clipping related when bounding
> boxes
> > of big
> > polygons are touched when zooming in or printing on
> high
> > resolutions.
> > I am glad to hear that I am not the only person
> > experiencing these
> > problems - seems to be a real issue.
> > Andreas
> > wrote:
> > > Hi,
> > > I have a PostGIS table & shapefile of the
> New
> > Zealand coast (1:50,000)
> > > If I open this table it plots in a fraction of a
> > second, pretty much as expected, with similar speeds
> for
> > both the shapefile & table.
> > > However, if I zoom in, the redraw takes three
> minutes
> > or more.
> > > While I'm waiting for the refresh, Qgis is
> showing
> > 100% cpu load, postgres isn't showing at all (top). On
> an
> > AMD dual core 3.2Ghz cpu with 8Gb ram it should not
> take
> > anything like this long, and with earlier versions of
> Qgis
> > (pre 1.0) it was much faster.
> > > Performance is similar with both table &
> shapefile
> > data sources, so it does not seem Postgres related.
> > > However, plotting lines, points or polygons with
> tens
> > of thousands of features rendered works well, it seems
> to
> > primarily be polygons with many vertices (not even
> any
> > holes) that are the problem.
> > > OpenSuse 11.1, Qgis 1.2.0, Postgis table
> described
> > below, only 3 features/records, indexed &
> vacuumed.
> > > Does anyone have any idea what may be the issue?
> > > I can provide an ssh login if anyone wants to
> test
> > this for themselves.
> > > Thanks,
> > >    Brent Wood
> >   Table "public.coast_poly"
> > >  Column  |
> >    Type
> >         Modifiers
> > >  gid     | integer
> >              | not
> > null default nextval('coast_poly_gid_seq'::regclass)
> > >  id      | bigint
> > >  fid     | bigint
> > >  name    | character varying(42) |
> > >  geom_ll | geometry
> > > Indexes:
> > >     "coast_poly_pkey" PRIMARY KEY,
> > btree (gid)
> > >     "coast_poly_geom_ll_gist" gist
> > (geom_ll)
> > > Check constraints:
> > >     "enforce_dims_geom_ll" CHECK
> > (ndims(geom_ll) = 2)
> > >     "enforce_geotype_geom_ll"
> > CHECK (geometrytype(geom_ll) = 'MULTIPOLYGON'::text
> OR
> > geom_ll IS NULL)
> > >     "enforce_srid_geom_ll" CHECK
> > (srid(geom_ll) = 4326)
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
