R: Re: R: Re: [Qgis-user] manage R behaviour
alessandro.sarretta at inwind.it alessandro.sarretta at inwind.it
Tue Sep 1 02:17:46 PDT 2009
Hi Agus,
in Windows this doesn't work.. :-(
I can set the Working directory,
but if I use getwd() I can't see anything...
Ale
>----Messaggio originale----
>Da: alobolistas at gmail.com
>Data: 01/09/2009 11.00
>A: "alessandro.
sarretta at inwind.it"<alessandro.sarretta at inwind.it>
>Cc: <carson.farmer at gmail.
com>, <qgis-user at lists.osgeo.org>
>Ogg: Re: R: Re: [Qgis-user] manage R
behaviour
>What I have on ubuntu janty with qgis 1.2.0 is:
>>  setwd
("/media/Transcend/QGIS_EXPERIMENTAL/Rcatuav2")
> > ls()
>character(0)
> load(".RData")
> > ls()
>[1] "flCAST" "flFSTF"
>[3] "flightlines"
"flPC"
>and everything seems to work.
>Perhaps you should add a load
workspace button within tab "Workspace". I
>initially
>thought that the .RData
file would be loaded by default (which is
>probably not
>a good idea)
>I
like this version of manageR a lot!
>Agus
wrote:
>> Hi Carson,
>> I tried with a simple point layer called "SAMA".
Data are loaded
>> correctly, but if I try to use "ls()" or "names(SAMA)" I
have no
>> results...
>> If I instead do plot(SAMA$X) I obtain correctly
the plot.
>> So data are loaded, it seems a problem with the "print" output
on the
>> manageR console....
>> Tell me if I can test something...
thanks
>> Ale
>>     Da: carson.
farmer at gmail.com
>>     Data: 26/08/2009 11.10
>>     A: "Alessandro Sarretta"
>>     Cc: <qgis-user at lists.osgeo.org>
Ogg: Re: [Qgis-user] manage R behaviour
>>     Hi guys,
>>     Does any
of the text show up after you load a layer via Ctrl-L or
>>     anything like
that?
>>     What about if you try to save a graphic (this should export a
>>     command to the manageR console)?
>>     Based on the versions of the
various software required, I can't
>>     see why this isn't working.
>>     It
must be a Windows thing, but unfortunately, I don't have access
>>     to a
Windows machine at the moment.
>>     Cheers,
>>     Carson
>>     On
Tue, Aug 25, 2009 at 10:12 PM, Alessandro Sarretta
>>     <alessandro.
>>     <mailto:alessandro.sarretta at inwind.it>> wrote:
>>         Hi Carson,
>>         same behaviour for me, using QGIS trunk e QGIS
1.1, installed
>>         by OSGeo4W in Windows XP.
>>         R2.9.0
>>         manageR 0.7.2
>>         qt4-libs 4.5.2-1
>>         pyqt4 4.5.2-5
>>         python-rpy2 2.0.3-1
>>         and congratulations, your
plugin is improving really well!
>>         thanks
>>         Ale
>>         Carson Farmer ha scritto:
>>             Hi Filip,
>>                Dear all,
>>                I finally got to work manage R
plug-in (version 0.7.2
>>             woks, I use
>>                R 2.9.1,
>>                Qgis 1.0.2, Win XP).
>>                But I am confused by
its behaviour. The console doesn't
>>             return any
results.
>>                I mean, when I type:
>>                $ x<-1
>>                $ y<-2
>>                $ x+y
>>                Nothing
is returned, even though the variables x and y
>>             exist (they are
>>                listed on the Environment tab).
>>                However,
when I load a shape file with Ctrl+L, the
>>             console writes
>>                out a
>>                message
>>                "QGIS
Vector Layer
>>                Is this a
standard behaviour of manage R?
>>              no it is not the standard
behaviour... I'm not sure why
>>             you aren't getting any output to
the console with normal R
>>             commands.
>>             I haven't
testing this plugin on Windows yet, so perhaps
>>             I'll give this a
try tonight and see if I can get the same
>>             behaviour.
>>             What versions of Qt and Rpy are you running?
>>     Carson Farmer
>>     National Centre for Geocomputation
>>     John Hume Building,
>>     National University of Ireland, Maynooth,
>>     Maynooth,
>>     Co. Kildare,
>>     Ireland.
>>     www.carsonfarmer.
com <http://www.carsonfarmer.com>
>> Qgis-user mailing list
Qgis-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
