[Qgis-user] Resolved: Projection
Sarel Coetzer geotech.sarel at gmail.com
Tue Sep 1 03:47:03 PDT 2009
Hi Carson
Thanks for the input.
The "refresh" occurs only when the OTF facility is enabled.
So the procedure is:
- Start QGIS and enable OTF
- Load layerfiles
- Change CRS ->Refresh occurs automatically to selected projection
Regards
Sarel
On Tue, Sep 1, 2009 at 11:16 AM, Carson Farmer <carson.farmer at gmail.com>wrote:
> Sarel,
> You certainly shouldn't have to save the shapefile to get the correct
> projection... did you try refreshing the mapcanvas after enabling on the fly
> projection (though this shouldn't be required either)?
> Carson
> On Mon, Aug 31, 2009 at 8:13 PM, Sarel Coetzer <geotech.sarel at gmail.com>wrote:
>> Hi Magnus
>> I am using shapefiles. I had to save the shapefile with the new CRS to get
>> the projection correct and reload.
>> Sarel
>> On Mon, Aug 31, 2009 at 9:02 PM, Magnus Homann <magnus at homann.se> wrote:
>>> Sarel Coetzer skrev:
>>>> Hi Giovanni
>>>> Yes I have tried the OTF facility and still the layers wont overlay. The
>>>> issue is that changes can be made to the CRS but it does not take effect
>>>> until the layer file is saved with the new CRS values and is required to be
>>>> reloaded in a new session. Surely the layers should refresh with the newly
>>>> selected CRS and display in the correct location unless I am missing
>>>> something fundamentally.
>>> Yes, it should change immediately.
>>> Is it raster or vector layer? Rasters won't reproject.
>>> Magnus
>> http://sarelgis.blogspot.com/
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Carson Farmer
> National Centre for Geocomputation
> John Hume Building,
> National University of Ireland, Maynooth,
> Maynooth,
> Co. Kildare,
> Ireland.
> www.carsonfarmer.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090901/e1c4b1a6/attachment.html>
