[Qgis-user] QGis 1.2.0 Daphnis
Arnaud Vandecasteele arnaud.sig at gmail.com
Fri Sep 4 06:14:14 PDT 2009
Hi Giovanni,
Thanks you for your to answer me.
Before the 1.2 i used to work with Qgis Kore. I followed the launchpad
indication and had the UbunutuGis sources in Synaptic.
After that in Synaptic I've updated my Qgis application.
Should I remove all of them before?
Regards
Arnaud
On Fri, Sep 4, 2009 at 5:08 PM, Giovanni Manghi
<giovanni.manghi at gmail.com>wrote:
> Hi,
> I have already installed a few times (on different machines) qgis 1.2
> under ubuntu 9.04 using repositories or compiling from source, and I
> have never hit your problem. How did you installed qgis? Did you had
> any previous version already installed?
> -- Giovanni --
> On Fri, Sep 4, 2009 at 2:02 PM, Arnaud
> Vandecasteele<arnaud.sig at gmail.com> wrote:
> > I all,
> > Before to open a ticket on the track list I would like to know if someone
> > has already got the same problem as I get with the brand new QGis version
> > (1.2.0).
> > Everything works fine except the Grass Plugin. Indeed when i trie to
> > activate it by the Manage plugin menu Qgis crash.
> > In my shell i got this error message : /usr/bin/qgis.bin: symbol lookup
> > error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G__no_gisinit.
> > I work in Ubuntu  9.04 - Jaunty Jackalope.
> > If someone can help me to understand what is wrong.
> > Best regards
> > Arnaud
> > Van De Casteele Arnaud
> > 72 Rue de la colline des camélias 97400 Saint-Denis
> > 0262 30 67 79 - 0692 76 24 48
> > SIG - WebMapping - GPS embarqué
> > Site internet : http://geotribu.net/
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090904/9b3009b9/attachment.html>
