[Qgis-user] QGis 1.2.0 Daphnis
Arnaud Vandecasteele
arnaud.sig at gmail.com
Fri Sep 4 06:23:15 PDT 2009
After a apt_get upgrade the grass plugin reworks.
Sorry for the disturbs.
Arnaud
On Fri, Sep 4, 2009 at 5:14 PM, Arnaud Vandecasteele
<arnaud.sig at gmail.com>wrote:
> Hi Giovanni,
> Thanks you for your to answer me.
> Before the 1.2 i used to work with Qgis Kore. I followed the launchpad
> indication and had the UbunutuGis sources in Synaptic.
> After that in Synaptic I've updated my Qgis application.
> Should I remove all of them before?
> Regards
> Arnaud
> On Fri, Sep 4, 2009 at 5:08 PM, Giovanni Manghi <giovanni.manghi at gmail.com
> > wrote:
>> Hi,
>> I have already installed a few times (on different machines) qgis 1.2
>> under ubuntu 9.04 using repositories or compiling from source, and I
>> have never hit your problem. How did you installed qgis? Did you had
>> any previous version already installed?
>> -- Giovanni --
>> On Fri, Sep 4, 2009 at 2:02 PM, Arnaud
>> Vandecasteele<arnaud.sig at gmail.com> wrote:
>> > I all,
>> > Before to open a ticket on the track list I would like to know if
>> someone
>> > has already got the same problem as I get with the brand new QGis
>> version
>> > (1.2.0).
>> > Everything works fine except the Grass Plugin. Indeed when i trie to
>> > activate it by the Manage plugin menu Qgis crash.
>> > In my shell i got this error message : /usr/bin/qgis.bin: symbol lookup
>> > error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G__no_gisinit.
>> > I work in Ubuntu 9.04 - Jaunty Jackalope.
>> > If someone can help me to understand what is wrong.
>> > Best regards
>> > Arnaud
>> > Van De Casteele Arnaud
>> > 72 Rue de la colline des camélias 97400 Saint-Denis
>> > 0262 30 67 79 - 0692 76 24 48
>> > SIG - WebMapping - GPS embarqué
>> > Site internet : http://geotribu.net/
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090904/46946b2a/attachment.html>
