[Qgis-user] QGis 1.2.0 and OpenStreetMap plugin on Windows
Werner Macho werner.macho at gmail.com
Tue Sep 8 08:02:15 PDT 2009
Hi!
Well - I tried that on my WindowsXP right now and you're correct - Data
gets NOT displayed ..
Even the preselected(?) Path to download the osm file to is written in
"*NIX" Notation .. "/tmp/090908_165843_downloaded.osm"
So we can see the differences between windows "C:\" and Unix "/" - jef?
any solution for that?
What happened to the data that should be displayed i cannot tell - I can
just confirm that there should be something and believe me - on my
Ubuntu Box at home - there IS something ;) But that doesn't help here
either .. (Probably you have a non Windows PC somewhere where you can
work on)
Downloading a plugin is NOT necessary any more as the OSM Provider is
now in SVN trunk and gets compiled and is integrated into QGIS so no
need to download anything else.
It seems that theres just something fishy inside OSM with Windows.
Hope that helps you for now
regards
Werner
Rahkonen Jukka schrieb:
> Hi,
> I downloaded Qgis 1.2.0 Windows installer from
> http://download.osgeo.org/qgis/win32/QGIS-1.2.0-0-No-GrassSetup.exe
> and installed it successfully on my computer running on Vista Business.
> Next I launched the application and installed the OpenStreetMap plugin
> through the plugin manager. So far everything is OK. I can open my old
> OSM files saved in osm.xml format and download OSM data directly from
> OSM server. What is sad is that I cannot see anything on a map. Three
> layers appear to the layer list and attribute tables show all the nice
> attributes. Thus the data must be there but the map window remains
> blank. Is Windows version of QGis 1.2.0 missing something or should I do
> some additional installations before I can see OSM data in QGis? From
> the old mails from June 2009 I read about downloading something called
> OSM provider and recompiling QGis before installing OSM plugin. Is that
> still necessary? If it is I will back down.
> -Jukka Rahkonen-
> Qgis-user mailing list
