[Qgis-user] QGis 1.2.0 and OpenStreetMap plugin on Windows
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Tue Sep 8 23:53:45 PDT 2009
Thanks, your answer helps me a lot because I can stop wasting time for
trials. I am awaiting the Windows version that shows OSM features.  QGis
supporting OSM is extremely nice thing because it is narrowing the gap
between OSM and GIS worlds. It is for sure worth advertising on OSM wiki
and mailing lists. For example it probably supports using local imagery
as a background that is missing from all the existing OSM editors.
-Jukka Rahkonen-
Werner Macho wrote:
> Hi!
> Well - I tried that on my WindowsXP right now and you're
> correct - Data gets NOT displayed ..
> Even the preselected(?) Path to download the osm file to is
> written in "*NIX" Notation .. "/tmp/090908_165843_downloaded.osm"
> So we can see the differences between windows "C:\" and Unix
> "/" - jef?
> any solution for that?
> What happened to the data that should be displayed i cannot
> tell - I can just confirm that there should be something and
> believe me - on my Ubuntu Box at home - there IS something ;)
> But that doesn't help here either .. (Probably you have a non
> Windows PC somewhere where you can work on)
> Downloading a plugin is NOT necessary any more as the OSM
> Provider is now in SVN trunk and gets compiled and is
> integrated into QGIS so no need to download anything else.
> It seems that theres just something fishy inside OSM with Windows.
> Hope that helps you for now
> regards
> Werner
> Rahkonen Jukka schrieb:
> > Hi,
> > I downloaded Qgis 1.2.0 Windows installer from
> > http://download.osgeo.org/qgis/win32/QGIS-1.2.0-0-No-GrassSetup.exe
> > and installed it successfully on my computer running on
> Vista Business.
> > Next I launched the application and installed the
> > through the plugin manager. So far everything is OK. I can
> open my old
> > OSM files saved in osm.xml format and download OSM data
> directly from
> > OSM server. What is sad is that I cannot see anything on a
> map. Three
> > layers appear to the layer list and attribute tables show
> all the nice
> > attributes. Thus the data must be there but the map window remains
> > blank. Is Windows version of QGis 1.2.0 missing something
> or should I
> > do some additional installations before I can see OSM data in QGis?
> > From the old mails from June 2009 I read about downloading
> something
> > called OSM provider and recompiling QGis before installing
> OSM plugin.
> > Is that still necessary? If it is I will back down.
> > -Jukka Rahkonen-
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
