[Qgis-user] QGIS hanging and bad shapefile export
Tim Sutton lists at linfiniti.com
Wed Sep 9 15:27:00 PDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Gavin
I am busy preparing a new all-in-one windows installer of QGIS 1.2.0-1
Daphnis built against gdal 1.6 rather than 1.5. Lets test to see if that
resolves the issue. The build also fixes issues with image display when
using evis under windows. I'll post a note here when its ready.
Regards
Tim
Gavin Fleming wrote:
> I'm continuing this thread as the problem seems related:
> QGIS hangs on zooming close into polygon layers. We experience the
> problem on 2 PCs running Win XP. QGIS has been doing this for several
> versions, including now 1.2. The number of zooms or the extent of the
> zoom might vary but every time it hangs (or takes and EXTREMELY long
> time to zoom) when zoomed in close. This makes it extremely frustrating
> if not impossible to do detailed work such as editing. And it happens
> with shapefiles and PostGIS layers.
> The problem does not present in QGIS 1.0.0 on Ubuntu. Seeing Marco's
> answer below to a similar problem (zooming to a selected table record)
> it seems like the common factor might be XP.
> This should be tested and fixed on XP as it is still widely used,
> especially on systems with ArcGIS as ArcGIS (9.2 at least) doesn't run
> on Vista, so this bug could a major impact on QGIs acceptance for people
> running dual or transition environments.
> Gavin Fleming
> Also posted at
> http://forum.qgis.org/viewtopic.php?f=2&t=4936&p=8628#p8628
> -----Original Message-----
> From: Marco Pasetti [mailto:marcopstt at gmail.com]
> Sent: 2008 September 10 11:36
> To: Gavin Fleming; qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] QGIS hanging and bad shapefile export
> Hi Gavin,
>> Two problems have been occurring regularly in QGIS (0.11 on XP)
>> Open attribute table, select one or more records, click 'Zoom to
> selected
>> records' - QGIS hangs.
> I tested it on my notebook running Windows Vista Home Premium (where the
> releases of QGIS and GRASS for MS-Windows are built and packaged).
> After loading a shapefile I quickly zoomed on selected records from the
> attribute table; no bugs reported.
> I tested the same thing loading a GRASS vector layer: same result, no
> problem at all.
> I guess it's a specific XP problem, but, at the moment, I don't have an
> XP
> machine to test on.
>> Export as shapefile (PostGIS layer): ArcGIS does not recognise the
> extent
>> of the shapefile and will not draw it, though attributes are
> accessible. If
>> you then export it as a shapefile again >from within ArcGIS, the output
>> shapefile is fixed and draws fine. Is this a PostGIS / shapelib / QGIS
>> problem? What's the fix?
> I'm afraid, I don't have ArcGIS (nor any ESRI product, actually).
> Regards,
> Marco
> This message is intended for the addressee only.Information and attachments in this e-mail may contain confidential, proprietary, or legally privileged information.
> If you are not the intended recipient, or responsible for delivery of the message to the intended recipient, any disclosure, copying, distribution, or any action taken is prohibited and may be unlawful, and could result in a claim against you.
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkqoK7MACgkQqk07qZdiYje6egCgmdykb+W5o+mgRkmD9g2BUHIk
lCgAoLyr78k++kBSNGRqo16JUyAbD0GK
=bC1N
-----END PGP SIGNATURE-----
