[Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not work]
Lionel Roubeyrie lroubeyrie at limair.asso.fr
Fri Sep 11 03:24:16 PDT 2009
Hi Augustin,
make a purge before reinstalling qgis, and all should be ok (sudo apt-get purge
qgis*)
Agustin Lobo a écrit :
> Follow up: using
> sudo apt-get install qgis-plugin-grass
> instead of Synaptic and having  libgdal1-1.6.0  previously
> installed (and not having libgdal1-1.5.0),
> does not install libgdal1-1.5.0, but QGIS still crashes with the same
> message
> Agus
> -------- Original Message --------
> Subject:     Binary QGIS 1.2.0.2~jaunty + GRASS does not work
> Date:     Fri, 11 Sep 2009 11:56:33 +0200
> From:     Agustin Lobo <alobolistas at gmail.com>
> Reply-To:     Agustin.Lobo at ija.csic.es
> To:     qgis-user <qgis-user at lists.osgeo.org>, qgis-developer
> <qgis-developer at lists.osgeo.org>
> After upgrading to QGIS 1.2.0.2~jaunty, the python grass
> plugin still installs libgdal1-1.5.0 (+ grass 6.4.0~rc5-2~jaunty)
> and QGIS crashes upon start up with message:
> "Uncatched fatal GRASS error. Incompatible library version for module.
> You need to rebuild GRASS or untangle multiple installations"
> Removing libgdal1-1.6.0  does not solve the problem
> Removing libgdal1-1.5.0  (now you can do it without automatic uninstal
> of the grass plugin) and installing libgdal1-1.6.0  does not solve the
> problem either.
> Grass runs fine independently in all cases.
> Qgis runs fine without the grass plugin
> Agus
> Qgis-user mailing list
Lionel Roubeyrie - lroubeyrie at limair.asso.fr
Chargé d'études et de maintenance
LIMAIR - la Surveillance de l'Air en Limousin
http://www.limair.asso.fr
