[Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not work]
Agustin Lobo
alobolistas at gmail.com
Fri Sep 11 04:03:42 PDT 2009
I've done:
sudo apt-get remove grass
sudo apt-get remove qgis
sudo apt-get purge
sudo apt-get autoremove
sudo apt-get autoclean
sudo apt-get install qgis
sudo apt-get purge
Same problem at qgis startup.
Qgis starts if I do:
sudo apt-get remove qgis-plugin-grass
Agus
Lionel Roubeyrie wrote:
> Hi Augustin,
> make a purge before reinstalling qgis, and all should be ok (sudo
> apt-get purge qgis*)
> Agustin Lobo a écrit :
>> Follow up: using
>> sudo apt-get install qgis-plugin-grass
>> instead of Synaptic and having libgdal1-1.6.0 previously
>> installed (and not having libgdal1-1.5.0),
>> does not install libgdal1-1.5.0, but QGIS still crashes with the same
>> message
>> Agus
>> -------- Original Message --------
>> Subject: Binary QGIS 1.2.0.2~jaunty + GRASS does not work
>> Date: Fri, 11 Sep 2009 11:56:33 +0200
>> From: Agustin Lobo <alobolistas at gmail.com>
>> Reply-To: Agustin.Lobo at ija.csic.es
>> To: qgis-user <qgis-user at lists.osgeo.org>, qgis-developer
>> <qgis-developer at lists.osgeo.org>
>> After upgrading to QGIS 1.2.0.2~jaunty, the python grass
>> plugin still installs libgdal1-1.5.0 (+ grass 6.4.0~rc5-2~jaunty)
>> and QGIS crashes upon start up with message:
>> "Uncatched fatal GRASS error. Incompatible library version for module.
>> You need to rebuild GRASS or untangle multiple installations"
>> Removing libgdal1-1.6.0 does not solve the problem
>> Removing libgdal1-1.5.0 (now you can do it without automatic uninstal
>> of the grass plugin) and installing libgdal1-1.6.0 does not solve
>> the problem either.
>> Grass runs fine independently in all cases.
>> Qgis runs fine without the grass plugin
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090911/16e8f619/attachment.vcf>
