[Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not work]
Agustin Lobo
alobolistas at gmail.com
Fri Sep 11 12:38:45 PDT 2009
Jürgen E. Fischer wrote:
> On Fri, 11. Sep 2009 at 13:55:42 +0200, Agustin Lobo wrote:
>> In grass
>> r.in.gdal -o
>> input=/media/Transcend/ANYELLA/catuav20090730/tif/SDIM0178.tif
>> output=delmetif
> That's the wrong direction. You need to access GRASS from GDAL not vice
> versa.
> gdalinfo $HOME/grass/spearfish60/PERMANENT/cellhd/elevation.10m
I think the problem is in gdal:
$ gdalinfo
/media/Transcend/MONTSENY2008/Carlos_Montseny/GrassData/GrassData/carlos/A_TOTAL/cellhd/delmetif.blue
Segmentation fault
> That's strange. Try
> apt-cache rdepends libgdal1-1.5.0
> to see what depends on libgdal1-1.5.0. There shouldn't be anything qgis or
> grass related except for libgdal1-1.5.0-grass.
$ apt-cache rdepends libgdal1-1.5.0
libgdal1-1.5.0
Reverse Depends:
python-mapscript
php5-mapscript
perl-mapscript
mapserver-bin
libmapscript-ruby1.9
libmapscript-ruby1.8
libmapnik0.5
cgi-mapserver
python-mapscript
python-gdal
php5-mapscript
perl-mapscript
mapserver-bin
libopenscenegraph7
libmapnik0.5
libgdal1-dev
libgdal-ruby1.8
libgdal-perl
libgdal-doc
grass
gdal-bin
cgi-mapserver
The weird thing is that according to Synaptic libgdal1-1.5.0-grass is
not installed
(I removed it with apt-get remove after installing the qgis-grass-plugin)
How can I check with apt if libgdal1-1.5.0-grass is installed or not?
> And try
> apt-cache depends qgis-plugin-grass
> to see what qgis-plugin-grass depends on. There should only be the dependency
> to one of the libgdal1-*-grass packages - and that should be satisfiable by
> installing libgdal1-1.6.0-grass.
$ apt-cache depends qgis-plugin-grass
qgis-plugin-grass
Depends: qgis
Depends: qgis-plugin-grass-common
Depends: libc6
Depends: libgcc1
Depends: libgdal1-1.6.0
Depends: libgeos-c1
Depends: libproj0
Depends: libqgis1.2.0
Depends: libqt4-network
Depends: libqt4-sql
Depends: libqt4-svg
Depends: libqt4-xml
Depends: libqtcore4
Depends: libqtgui4
Depends: libstdc++6
|Depends: <libgdal1-1.4.0-grass>
|Depends: libgdal1-1.5.0-grass
Depends: libgdal1-1.6.0-grass
it depends on bot libgdal1-1.5.0-grass and libgdal1-1.&.0-grass ?
Thanks for your help!
Agus
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090911/296e0961/attachment.vcf>
