[Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not work]
Jürgen E. Fischer jef at norbit.de
Fri Sep 11 15:28:11 PDT 2009
Hi Agus,
On Fri, 11. Sep 2009 at 21:38:45 +0200, Agustin Lobo wrote:
> I think the problem is in gdal:
> $ gdalinfo
> /media/Transcend/MONTSENY2008/Carlos_Montseny/GrassData/GrassData/carlos/A_TOTAL/cellhd/delmetif.blue
> Segmentation fault
Yes.  The gdal grass plugin needed and rebuild after GRASS was updated.
Alan just took care about that.  Another upgrade should fix it.
> $ apt-cache rdepends libgdal1-1.5.0
> libgdal1-1.5.0
> Reverse Depends:
>  grass
Which grass is that (apt-cache policy grass)?
That's what triggers the dependency to gdal 1.5. The ubuntugis jaunty grass
depends on libgdal1-1.6.0.  So your grass must be from a different repository.
> $ apt-cache depends qgis-plugin-grass
> |Depends: <libgdal1-1.4.0-grass>
> |Depends: libgdal1-1.5.0-grass
>  Depends: libgdal1-1.6.0-grass
> it depends on bot libgdal1-1.5.0-grass and libgdal1-1.&.0-grass ?
No, that's an "or".  So any grass gdal plugin will fullfil the dependency.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
