[Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not work]
Agustin Lobo
alobolistas at gmail.com
Sat Sep 12 12:45:17 PDT 2009
Thanks Jurgen,
Jürgen E. Fischer wrote:
> Hi Agus,
> On Fri, 11. Sep 2009 at 21:38:45 +0200, Agustin Lobo wrote:
>> I think the problem is in gdal:
>> $ gdalinfo
>> /media/Transcend/MONTSENY2008/Carlos_Montseny/GrassData/GrassData/carlos/A_TOTAL/cellhd/delmetif.blue
>> Segmentation fault
> Yes. The gdal grass plugin needed and rebuild after GRASS was updated.
> Alan just took care about that. Another upgrade should fix it.
Great news!
>> $ apt-cache rdepends libgdal1-1.5.0
>> libgdal1-1.5.0
>> Reverse Depends:
>> grass
> Which grass is that (apt-cache policy grass)?
> That's what triggers the dependency to gdal 1.5. The ubuntugis jaunty grass
> depends on libgdal1-1.6.0. So your grass must be from a different repository.
$ apt-cache policy grass
grass:
Installed: 6.4.0~rc5-2~jaunty1
Candidate: 6.4.0~rc5-2~jaunty1
Version table:
*** 6.4.0~rc5-2~jaunty1 0
500 http://ppa.launchpad.net jaunty/main Packages
100 /var/lib/dpkg/status
6.2.3-2.1 0
500 http://archive.ubuntu.com jaunty/universe Packages
The ppa.launchpad.net repositories I have in sources.list are:
deb http://ppa.launchpad.net/openoffice-pkgs/ppa/ubuntu jaunty main
deb-src http://ppa.launchpad.net/openoffice-pkgs/ppa/ubuntu jaunty main
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu jaunty main
deb-src http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu jaunty main
is the grass 6.2.3-2.1 0 from archive.ubuntu.com causing problems?
Is there any way to specify the actual repository in case a package
is available in more than one repository?
Agus
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090912/62996683/attachment.vcf>
