[Qgis-user] Quantum Connect to PostgreSQL
pcreso at pcreso.com pcreso at pcreso.com
Sun Sep 13 20:42:12 PDT 2009
Hi Chris,
Have you enabled TCP/IP access in pg_hba.conf?
QGIS uses a network socket connection whether or not it is on a local host, so Postgres needs to enable such connections.
Brent Wood
--- On Mon, 9/14/09, chris Wild <chrismwild at gmail.com> wrote:
> From: chris Wild <chrismwild at gmail.com>
> Subject: [Qgis-user] Quantum Connect to PostgreSQL
> To: qgis-user at lists.osgeo.org
> Date: Monday, September 14, 2009, 3:29 PM
> Dear All
> We are trying to set up a Quantum connection to a POSTGIS
> database using Port 5432.
> The connection comes back "Refused" each time. We
> have also tried an ODBC driver based connection to the
> database and it also is refused.
> The exact message is:
> The database said:
> Could not connect to server: Connection Refused
> All firewalls are open for  Port 5432 and the server
> router is logging packets getting through it.
> Can anyone help?
> Best Wishes
> Tony Lindsay
> -----Inline Attachment Follows-----
> Qgis-user mailing list
