[Qgis-user] Quantum Connect to PostgreSQL
Andreas Neumann a.neumann at carto.net
Sun Sep 13 23:35:05 PDT 2009
also make sure that the SSL mode setting is correct - not to mention
user/pw of course ...
Can you connect from other machines with other software (e.g. pgadmin3)
using the same settings?
Andreas
On Mon, September 14, 2009 5:42 am, pcreso at pcreso.com wrote:
> Hi Chris,
> Have you enabled TCP/IP access in pg_hba.conf?
> QGIS uses a network socket connection whether or not it is on a local
> host, so Postgres needs to enable such connections.
> Brent Wood
> --- On Mon, 9/14/09, chris Wild <chrismwild at gmail.com> wrote:
>> From: chris Wild <chrismwild at gmail.com>
>> Subject: [Qgis-user] Quantum Connect to PostgreSQL
>> To: qgis-user at lists.osgeo.org
>> Date: Monday, September 14, 2009, 3:29 PM
>> Dear All
>> We are trying to set up a Quantum connection to a POSTGIS
>> database using Port 5432.
>> The connection comes back "Refused" each time. We
>> have also tried an ODBC driver based connection to the
>> database and it also is refused.
>> The exact message is:
>> The database said:
>> Could not connect to server: Connection Refused
>> All firewalls are open for  Port 5432 and the server
>> router is logging packets getting through it.
>> Can anyone help?
>> Best Wishes
>> Tony Lindsay
>> -----Inline Attachment Follows-----
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
