[Qgis-user] Add a column to the table of a vector object
Jürgen E. Fischer jef at norbit.de
Wed Sep 16 13:38:36 PDT 2009
Hi Agus,
On Wed, 16. Sep 2009 at 19:04:11 +0200, Agustin Lobo wrote:
> I have to add a column (field) to the table of a vector object and populate
> it with values I have in a text file (resulting from a process in R).
If you can create a DBF file instead you could use fTools' "Join Attributes".
If that's not possible, you could probably use OpenOffice to create a DBF from
that file.
> I know I can create an empty new field with Table Manager.
Just for the record.  Given a recent GDAL (ie >=1.6) you don't need the table
manager to add fields to shapes anymore.  GDAL and in turn QGIS can do it on
it's own.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
