[Qgis-user] Georeferencer plugin and helmert method
Alex Mandel tech_dev at wildintellect.com
Mon Sep 21 09:47:32 PDT 2009
Ziegler Stefan wrote:
> Hi
> I'm trying to use the helmert transform method in the georeferencer plugin. QGIS (code revision 11761) crashes after hitting the ok button of the "A Helmert transform requires ...." message box. All the other methods are working.
> Is anybody using the helmert method with success?
> regards
> Stefan
It's always crashed on me since way back in the day (0.9ish), we should
probably just remove it, or put it at the end of the list. Polynomial is
the recommended method anyways.
Alex
