[Qgis-user] Compiling QGIS 1.2.0 with GRASS problems
Christy Nieman cnieman at dmsolutions.ca
Mon Sep 21 14:20:01 PDT 2009
Yes, I have grass-devel installed.
On 2009-09-21, at 3:09 PM, Micha Silver wrote:
> Christy Nieman wrote:
>> Micha,
>> Thanks for the reply.  I've tried on Fedora 9 and 11 64-bit, still
>> no luck.  Might it be the version of GRASS?  I'm runnin 6.3 from
>> the Fedora repositories.  Going try compiling GRASS 6.4.
> I also compiled 6.4.svn. But GRASS 6.3 from the repo should work.
> You do have the grass-devel rpm installed??
>> Christy
>>>> This problem is continuing with QGIS 1.3  I'm pretty sure I'm
>>>> specifying the right GRASS paths for QGIS to compile (as it
>>>> compiles happily with the QGIS 1.0.x versions), but have not
>>>> managed to get 1.2 or 1.3 to compile.  Has any one else
>>>> encountered this?
>>> This worked for me (Fedora 10 64 bit):
>>> cmake -DGRASS_PREFIX:PATH=/usr/local/grass/grass-6.4.0RC5/ -
>>> DCMAKE_INSTALL_PREFIX:PATH=/home/micha/qgis_1.3/ ..
>>> Maybe you'll also need:  |-DGDAL_LIBRARY:STRING=/usr/lib64/
>>> libgdal.so
>>> Before running make check thru all the paths and strings that
>>> cmake is using by doing
>>> cmake -L ..
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> This mail was received via Mail-SeCure System.
