[Qgis-user] Compiling QGIS 1.2.0 with GRASS problems
Micha Silver micha at arava.co.il
Mon Sep 21 12:09:29 PDT 2009
Christy Nieman wrote:
> Micha,
> Thanks for the reply.  I've tried on Fedora 9 and 11 64-bit, still no
> luck.  Might it be the version of GRASS?  I'm runnin 6.3 from the
> Fedora repositories.  Going try compiling GRASS 6.4.
I also compiled 6.4.svn. But GRASS 6.3 from the repo should work. You do
have the grass-devel rpm installed??
> Christy
>>> This problem is continuing with QGIS 1.3  I'm pretty sure I'm
>>> specifying the right GRASS paths for QGIS to compile (as it compiles
>>> happily with the QGIS 1.0.x versions), but have not managed to get
>>> 1.2 or 1.3 to compile.  Has any one else encountered this?
>> This worked for me (Fedora 10 64 bit):
>> cmake -DGRASS_PREFIX:PATH=/usr/local/grass/grass-6.4.0RC5/
>> -DCMAKE_INSTALL_PREFIX:PATH=/home/micha/qgis_1.3/ ..
>> Maybe you'll also need:  |-DGDAL_LIBRARY:STRING=/usr/lib64/libgdal.so
>> Before running make check thru all the paths and strings that cmake
>> is using by doing
>> cmake -L ..
> Qgis-user mailing list
> This mail was received via Mail-SeCure System.
