[Qgis-user] Compiling QGIS 1.2.0 with GRASS problems
Christy Nieman
cnieman at dmsolutions.ca
Mon Sep 21 11:50:21 PDT 2009
Micha,
Thanks for the reply. I've tried on Fedora 9 and 11 64-bit, still no
luck. Might it be the version of GRASS? I'm running 6.3 from the
Fedora repositories. Going try compiling GRASS 6.4.
Christy
Micha Silver wrote:
> Christy Nieman wrote:
>> This problem is continuing with QGIS 1.3 I'm pretty sure I'm
>> specifying the right GRASS paths for QGIS to compile (as it compiles
>> happily with the QGIS 1.0.x versions), but have not managed to get
>> 1.2 or 1.3 to compile. Has any one else encountered this?
> This worked for me (Fedora 10 64 bit):
> cmake -DGRASS_PREFIX:PATH=/usr/local/grass/grass-6.4.0RC5/
> -DCMAKE_INSTALL_PREFIX:PATH=/home/micha/qgis_1.3/ ..
> Maybe you'll also need: |-DGDAL_LIBRARY:STRING=/usr/lib64/libgdal.so
> Before running make check thru all the paths and strings that cmake is
> using by doing
> cmake -L ..
