[Qgis-user] Compiling QGIS 1.2.0 with GRASS problems
Micha Silver
micha at arava.co.il
Mon Sep 21 10:58:52 PDT 2009
Christy Nieman wrote:
> This problem is continuing with QGIS 1.3 I'm pretty sure I'm
> specifying the right GRASS paths for QGIS to compile (as it compiles
> happily with the QGIS 1.0.x versions), but have not managed to get 1.2
> or 1.3 to compile. Has any one else encountered this?
This worked for me (Fedora 10 64 bit):
cmake -DGRASS_PREFIX:PATH=/usr/local/grass/grass-6.4.0RC5/
-DCMAKE_INSTALL_PREFIX:PATH=/home/micha/qgis_1.3/ ..
Maybe you'll also need: |-DGDAL_LIBRARY:STRING=/usr/lib64/libgdal.so
Before running make check thru all the paths and strings that cmake is
using by doing
cmake -L ..
Micha
> Christy
>> Tim,
>> Thanks for your reply. I have made sure that it is looking in lib64,
>> and have tried explicitly specified the path for -D
>> GRASS_PREFIX=/usr/lib64/grass-6.3.0. I also tried adding -D
>> GRASS_INCLUDE_DIR=/usr/include/grass. I don't have time to kick at
>> this any more at the moment, will hopefully get back to it next week,
>> Christy
>> Tim Sutton wrote:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> Hi
>>> Sometimes on x86_64 libe land up in /usr/lib64 instead of /usr/lib -
>>> did
>>> you check cmake configs to make sure its looking for grass libs in the
>>> right place? You could try tweaking the cmake/FindGRASS.cmake file
>>> to do
>>> a better job of searching.
>>> Regards
>>> Tim
>>>> Hi,
>>>> I'm trying to compile QGIS 1.2.0 on Fedora 9 x86_64, but no matter
>>>> what
>>>> I try it says it cannot find GRASS (I have GRASS 6.3.0 installed). I
>>>> had no trouble getting 1.1.0 to compile and create the GRASS plugin
>>>> (from svn, not sure what revision it was, but I checked it on on July
>>>> 17th). I'm trying to create an RPM, and am using the same spec file
>>>> that worked for 1.1.0. Does anyone know offhand of things that have
>>>> changed that may be causing this problem?
>>>> Thanks,
>>>> Christy
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>> * QGIS programming and support services
>>> * Mapserver and PostGIS based hosting plans
>>> * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.9 (GNU/Linux)
>>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>>> iEYEARECAAYFAkqgNPkACgkQqk07qZdiYjc6iACg1jDSodv+r+DqjG2TbOghF65g
>>> abEAoNSZ+LCY+ZHLgqVGvrSE72Gi/Osx
>>> =oylg
>>> -----END PGP SIGNATURE-----
> This mail was received via Mail-SeCure System.
