[Qgis-user] Compiling QGIS 1.2.0 with GRASS problems
Christy Nieman
cnieman at dmsolutions.ca
Mon Sep 21 08:19:13 PDT 2009
This problem is continuing with QGIS 1.3 I'm pretty sure I'm specifying
the right GRASS paths for QGIS to compile (as it compiles happily with
the QGIS 1.0.x versions), but have not managed to get 1.2 or 1.3 to
compile. Has any one else encountered this?
Christy
Christy Nieman wrote:
> Tim,
> Thanks for your reply. I have made sure that it is looking in lib64,
> and have tried explicitly specified the path for -D
> GRASS_PREFIX=/usr/lib64/grass-6.3.0. I also tried adding -D
> GRASS_INCLUDE_DIR=/usr/include/grass. I don't have time to kick at
> this any more at the moment, will hopefully get back to it next week,
> Christy
> Tim Sutton wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi
>> Sometimes on x86_64 libe land up in /usr/lib64 instead of /usr/lib - did
>> you check cmake configs to make sure its looking for grass libs in the
>> right place? You could try tweaking the cmake/FindGRASS.cmake file to do
>> a better job of searching.
>> Regards
>> Tim
>>> Hi,
>>> I'm trying to compile QGIS 1.2.0 on Fedora 9 x86_64, but no matter what
>>> I try it says it cannot find GRASS (I have GRASS 6.3.0 installed). I
>>> had no trouble getting 1.1.0 to compile and create the GRASS plugin
>>> (from svn, not sure what revision it was, but I checked it on on July
>>> 17th). I'm trying to create an RPM, and am using the same spec file
>>> that worked for 1.1.0. Does anyone know offhand of things that have
>>> changed that may be causing this problem?
>>> Thanks,
>>> Christy
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>> iEYEARECAAYFAkqgNPkACgkQqk07qZdiYjc6iACg1jDSodv+r+DqjG2TbOghF65g
>> abEAoNSZ+LCY+ZHLgqVGvrSE72Gi/Osx
>> =oylg
>> -----END PGP SIGNATURE-----
