[Qgis-user] Compiling QGIS 1.2.0 with GRASS problems
Christy Nieman cnieman at dmsolutions.ca
Fri Sep 4 04:31:59 PDT 2009
Tim,
Thanks for your reply.  I have made sure that it is looking in lib64,
and have tried explicitly specified the path for -D
GRASS_PREFIX=/usr/lib64/grass-6.3.0.  I also tried adding -D
GRASS_INCLUDE_DIR=/usr/include/grass.  I don't have time to kick at this
any more at the moment, will hopefully get back to it next week,
Christy
Tim Sutton wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi
> Sometimes on x86_64 libe land up in /usr/lib64 instead of /usr/lib - did
> you check cmake configs to make sure its looking for grass libs in the
> right place? You could try tweaking the cmake/FindGRASS.cmake file to do
> a better job of searching.
> Regards
> Tim
> Christy Nieman wrote:
>> Hi,
>> I'm trying to compile QGIS 1.2.0 on Fedora 9 x86_64, but no matter what
>> I try it says it cannot find GRASS (I have GRASS 6.3.0 installed).  I
>> had no trouble getting 1.1.0 to compile and create the GRASS plugin
>> (from svn, not sure what revision it was, but I checked it on on July
>> 17th).  I'm trying to create an RPM, and am using the same spec file
>> that worked for 1.1.0.  Does anyone know offhand of things that have
>> changed that may be causing this problem?
>> Thanks,
>> Christy
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkqgNPkACgkQqk07qZdiYjc6iACg1jDSodv+r+DqjG2TbOghF65g
> abEAoNSZ+LCY+ZHLgqVGvrSE72Gi/Osx
> =oylg
> -----END PGP SIGNATURE-----
