[Qgis-user] Compiling QGIS 1.2.0 with GRASS problems
Tim Sutton lists at linfiniti.com
Thu Sep 3 14:28:32 PDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Sometimes on x86_64 libe land up in /usr/lib64 instead of /usr/lib - did
you check cmake configs to make sure its looking for grass libs in the
right place? You could try tweaking the cmake/FindGRASS.cmake file to do
a better job of searching.
Regards
Tim
Christy Nieman wrote:
> Hi,
> I'm trying to compile QGIS 1.2.0 on Fedora 9 x86_64, but no matter what
> I try it says it cannot find GRASS (I have GRASS 6.3.0 installed).  I
> had no trouble getting 1.1.0 to compile and create the GRASS plugin
> (from svn, not sure what revision it was, but I checked it on on July
> 17th).  I'm trying to create an RPM, and am using the same spec file
> that worked for 1.1.0.  Does anyone know offhand of things that have
> changed that may be causing this problem?
> Thanks,
> Christy
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkqgNPkACgkQqk07qZdiYjc6iACg1jDSodv+r+DqjG2TbOghF65g
abEAoNSZ+LCY+ZHLgqVGvrSE72Gi/Osx
=oylg
-----END PGP SIGNATURE-----
