[Qgis-user] qgis crash when using unique value classification of integer values
maning sambale emmanuel.sambale at gmail.com
Wed Sep 23 04:15:29 PDT 2009
1.3 ubuntu
On Wed, Sep 23, 2009 at 7:12 PM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
> I tested it and I have no problems qith qgis trunk under ubuntu.
> qhat platform are you using?
> On Wed, 2009-09-23 at 17:45 +0800, maning sambale wrote:
>> Get it here:
>> https://dl-web.getdropbox.com/get/Public/el_salvador_lcov_1992.zip?w=9e085715&dl=1
>> It is a small subset of landcover polygon (class category is encoded
>> in the "code" attribute).
>> We are encountering this issue when attribute values are in REAL type.
>>  The data was encoded as real value because of the issue I reported
>> with creating new polygon where the add attribute column only created
>> REAL value.
>> This issue is not evident with attributes in string and integer type.
>> On Wed, Sep 23, 2009 at 5:29 PM, Giovanni Manghi
>> > Hi,
>> > on what platform? shapes? postgis? can you post a sample to test
>> > locally?
>> > cheers
>> > -- Giovanni --
>> > On Wed, 2009-09-23 at 11:59 +0800, maning sambale wrote:
>> >> 1.3 crash when we classify polygons with unique value.  The attribute
>> >> value are integer number.
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
