[Qgis-user] qgis crash when using unique value classification of integer values
Giovanni Manghi giovanni.manghi at gmail.com
Wed Sep 23 04:12:16 PDT 2009
I tested it and I have no problems qith qgis trunk under ubuntu.
qhat platform are you using?
On Wed, 2009-09-23 at 17:45 +0800, maning sambale wrote:
> Get it here:
> https://dl-web.getdropbox.com/get/Public/el_salvador_lcov_1992.zip?w=9e085715&dl=1
> It is a small subset of landcover polygon (class category is encoded
> in the "code" attribute).
> We are encountering this issue when attribute values are in REAL type.
>  The data was encoded as real value because of the issue I reported
> with creating new polygon where the add attribute column only created
> REAL value.
> This issue is not evident with attributes in string and integer type.
> On Wed, Sep 23, 2009 at 5:29 PM, Giovanni Manghi
> <giovanni.manghi at gmail.com> wrote:
> > Hi,
> > on what platform? shapes? postgis? can you post a sample to test
> > locally?
> > cheers
> > -- Giovanni --
> > On Wed, 2009-09-23 at 11:59 +0800, maning sambale wrote:
> >> 1.3 crash when we classify polygons with unique value.  The attribute
> >> value are integer number.
