[Qgis-user] qgis crash when using unique value classification of integer values
maning sambale
emmanuel.sambale at gmail.com
Wed Sep 23 03:07:12 PDT 2009
let me correct the subject:
qgis crash when using unique value classification of REAL type values
On Wed, Sep 23, 2009 at 5:45 PM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> Get it here:
> https://dl-web.getdropbox.com/get/Public/el_salvador_lcov_1992.zip?w=9e085715&dl=1
> It is a small subset of landcover polygon (class category is encoded
> in the "code" attribute).
> We are encountering this issue when attribute values are in REAL type.
> The data was encoded as real value because of the issue I reported
> with creating new polygon where the add attribute column only created
> REAL value.
> This issue is not evident with attributes in string and integer type.
> On Wed, Sep 23, 2009 at 5:29 PM, Giovanni Manghi
> <giovanni.manghi at gmail.com> wrote:
>> Hi,
>> on what platform? shapes? postgis? can you post a sample to test
>> locally?
>> cheers
>> -- Giovanni --
>> On Wed, 2009-09-23 at 11:59 +0800, maning sambale wrote:
>>> 1.3 crash when we classify polygons with unique value. The attribute
>>> value are integer number.
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
cheers,
maning
