[Qgis-user] python-qgis pkg for Ubuntu 8.04
Jamie Adams
jaadfoo at gmail.com
Thu Sep 24 12:10:52 PDT 2009
I get a similar error when build qgis from svn. Reported it back in August,
still happening as of last week.
http://lists.osgeo.org/pipermail/qgis-developer/2009-August/007543.html
<http://lists.osgeo.org/pipermail/qgis-developer/2009-August/007543.html>I
get the error dialog when I start qgis, and then another when I close. I
fix it the same way, by removing the newline on line 16
of ui_qgsplugininstallerbase.py.
- Jamie
On Thu, Sep 24, 2009 at 11:59 AM, Micha Silver <micha at arava.co.il> wrote:
> This is aimed for Ubuntu package maintainers mostly.
> I think there's a small typo in one of the python scripts in the
> python_installer plugin that trips up installation of python-qgis and
> python-qgis-common.
> I was getting errors when running apt-get update with both the regular
> ubuntu repository and with ubuntugis. The error was:
> dpkg: dependency problems prevent configuration of python-qgis-common:
> python-qgis-common depends on python-qgis (>= 1.3.0-1~hardy3); however:
> Package python-qgis is not configured yet.
> dpkg: error processing python-qgis-common (--configure):
> dependency problems - leaving unconfigured
> Errors were encountered while processing:
> python-qgis-common
> Note that this error was somewhat bogus since the package *was* installed,
> and the python installer and other python plugins all seemed to work fine!
> Anyway:
> Running dpkg --configure python-qgi python-qgis-common, I saw this:
> micha at RMS:~$ sudo dpkg --configure python-qgis-common python-qgis
> Setting up python-qgis (1.3.0-1~hardy3) ...
> Setting up python-qgis-common (1.3.0-1~hardy3) ...
> Compiling
> /usr/share/qgis/python/plugins/plugin_installer/ui_qgsplugininstallerbase.py
> File
> "/usr/share/qgis/python/plugins/plugin_installer/ui_qgsplugininstallerbase.py",
> line 16
> QgsPluginInstallerDialogBase.setWindowIcon(QtGui.QIcon("
> SyntaxError: EOL while scanning single-quoted string
> pycentral: pycentral pkginstall: error byte-compiling files (88)
> I then opened the file ui_qgsplugininstallerbase.py and deleted the newline
> after QtGui.QIcon("
> so the new line looks like:
> QgsPluginInstallerDialogBase.setWindowIcon(QtGui.QIcon(""))
> Then I could run dpkg --configure successfully.
> Regards,
> Micha
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090924/32b686df/attachment.html>
