[Qgis-user] Segmentation fault
Marco Hugentobler
marco at hugis.net
Fri Sep 25 12:06:49 PDT 2009
Hi Anton
Which tool did you use for cutting out? The 'add Ring' tool or the 'reshape'
tool' (but that's only in 1.4)? I'm asking because normally the 'add Ring'
tools does not let you insert holes that cross feature borders.
Regards,
Marco
Am Donnerstag, 24. September 2009 18.39:08 schrieb Антон Николаевич:
> Hi.
> There is one bug which is in 1.1, 1.2, 1.3 and 1.4 version. I didn't
> check earlier versions.
> When I dvide a polygon into parts like this
> (http://img121.imageshack.us/img121/2061/34711052.png) and then cut them
> out like this (http://img19.imageshack.us/img19/3573/95451371.png), the
> program fails with segmentation fault.
> Qgis-user mailing list
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Honrainweg 5
CH-8038 Zürich
marco at hugis.net
http://homepage.hispeed.ch/hugis/
