[Qgis-user] QGIS 1.3.0 build error
Jacolin Yves yjacolin at free.fr
Mon Sep 28 01:03:14 PDT 2009
Hello,
Last week-end I sent an email about an issue when building QGIS 1.3.0 or
trunk. I succeed to remove this problem after building correctly SIP and
PyQt4.
I have now a new problem on this file :
raster_terrain_analysis/qgsrasterterrainanalysisdialog.h:21
[ 77%] Built target oracleplugin
[ 77%] Building CXX object
src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/qgsrasterterrainanalysisplugin.o
In file included
from /home/yjacolin/Documents/Logiciels/Sources/Geomatique/QGIS/qgis-1.3.0/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisdialog.h:21,
from /home/yjacolin/Documents/Logiciels/Sources/Geomatique/QGIS/qgis-1.3.0/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisplugin.cpp:27:
/home/yjacolin/Documents/Logiciels/Sources/Geomatique/QGIS/qgis-1.3.0/src/plugins/raster_terrain_analysis/ui_qgsrasterterrainanalysisdialogbase.h:30:
erreur: expected constructor, destructor, or type conversion before «class»
make[2]: ***
[src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/qgsrasterterrainanalysisplugin.o]
Erreur 1
make[1]: ***
[src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/all]
Erreur 2
make: *** [all] Erreur 2
Does this new plugin need to do something before building?
Thanks,
Y.
Yves Jacolin
Ne demandez pas si vous pouvez contribuer, contribuez ! :)
http://softlibre.gloobe.org
