[Qgis-user] QGIS 1.3.0 build error
Marco Hugentobler
marco at hugis.net
Mon Sep 28 01:23:14 PDT 2009
Hi Yves
Probably a Qt designer version issue. What Qt version are you using? Please
try to open the file ui/qgsrasterterrainanalysisdialogbase.ui with your Qt
designer version and save it.
Regards,
Marco
Am Montag, 28. September 2009 10.03:14 schrieb Jacolin Yves:
> Hello,
> Last week-end I sent an email about an issue when building QGIS 1.3.0 or
> trunk. I succeed to remove this problem after building correctly SIP and
> PyQt4.
> I have now a new problem on this file :
> raster_terrain_analysis/qgsrasterterrainanalysisdialog.h:21
> [ 77%] Built target oracleplugin
> [ 77%] Building CXX object
> src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/qgsr
>asterterrainanalysisplugin.o In file included
> from
> /home/yjacolin/Documents/Logiciels/Sources/Geomatique/QGIS/qgis-1.3.0/src/p
>lugins/raster_terrain_analysis/qgsrasterterrainanalysisdialog.h:21,
> from
>lugins/raster_terrain_analysis/qgsrasterterrainanalysisplugin.cpp:27:
>lugins/raster_terrain_analysis/ui_qgsrasterterrainanalysisdialogbase.h:30:
> erreur: expected constructor, destructor, or type conversion before «class»
> make[2]: ***
> [src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/qgs
>rasterterrainanalysisplugin.o] Erreur 1
> make[1]: ***
> [src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/all
>] Erreur 2
> make: *** [all] Erreur 2
> Does this new plugin need to do something before building?
> Thanks,
> Y.
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
