[Qgis-user] QGIS 1.3.0 build error
Jacolin Yves yjacolin at free.fr
Mon Sep 28 04:38:08 PDT 2009
Thanks! This works.
However I get another problem  :( Here are my release number:
* PyQt-x11-gpl-4.5.4
* qt-x11-opensource-src-4.5.2
* sip-4.8.2
In ccmake I configured parameters to use Qt-4.5.2 (no more, no less). After
installing QGIS 1.3.0 the about menu tells me that QGIS have been built with
Qt 4.3.4 and is running with Qt 4.3.4. I get also an error windows which
tells that PyQT4 couldn't be loaded and python will not be loaded :(
$ cmake . gives:
-- Python libraries found
-- Python bindings enabled
-- Found Qt-Version 4.5.2
All those issues seem linked each other. I mean I can't tell to QGIS to use Qt
4.5.2
Any idea? thanks
Y.
Le Monday 28 September 2009 10:23:14 Marco Hugentobler, vous avez écrit :
> Hi Yves
> Probably a Qt designer version issue. What Qt version are you using? Please
> try to open the file ui/qgsrasterterrainanalysisdialogbase.ui with your Qt
> designer version and save it.
> Regards,
> Marco
> Am Montag, 28. September 2009 10.03:14 schrieb Jacolin Yves:
> > Hello,
> > Last week-end I sent an email about an issue when building QGIS 1.3.0 or
> > trunk. I succeed to remove this problem after building correctly SIP and
> > PyQt4.
> > I have now a new problem on this file :
> > raster_terrain_analysis/qgsrasterterrainanalysisdialog.h:21
> > [ 77%] Built target oracleplugin
> > [ 77%] Building CXX object
> > src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/qg
> >sr asterterrainanalysisplugin.o In file included
> > from
> > /home/yjacolin/Documents/Logiciels/Sources/Geomatique/QGIS/qgis-1.3.0/src
> >/p lugins/raster_terrain_analysis/qgsrasterterrainanalysisdialog.h:21,
> > from
> >/p lugins/raster_terrain_analysis/qgsrasterterrainanalysisplugin.cpp:27:
> >/p
> > lugins/raster_terrain_analysis/ui_qgsrasterterrainanalysisdialogbase.h:30
> >: erreur: expected constructor, destructor, or type conversion before
> > «class» make[2]: ***
> > [src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/q
> >gs rasterterrainanalysisplugin.o] Erreur 1
> > make[1]: ***
> > [src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/a
> >ll ] Erreur 2
> > make: *** [all] Erreur 2
> > Does this new plugin need to do something before building?
> > Thanks,
> > Y.
Yves Jacolin
Ne demandez pas si vous pouvez contribuer, contribuez ! :)
http://softlibre.gloobe.org
