[Qgis-user] QGIS 1.3.0 build error
Jacolin Yves yjacolin at free.fr
Mon Sep 28 05:11:29 PDT 2009
Hello,
More info, I tried make test, here are the result:
55% tests passed, 5 tests failed out of 11
The following tests FAILED:
          3 - regression992 (Failed)
          5 - qgis_rasterlayertest (Failed)
          8 - qgis_rendererstest (Failed)
         10 - qgis_geometrytest (Failed)
         11 - qgis_vectoranalyzertest (SEGFAULT)
Errors while running CTest
make: *** [test] Erreur 8
thanks,
Y.
Le Monday 28 September 2009 13:38:08 Jacolin Yves, vous avez écrit :
> Thanks! This works.
> However I get another problem  :( Here are my release number:
> * PyQt-x11-gpl-4.5.4
> * qt-x11-opensource-src-4.5.2
> * sip-4.8.2
> In ccmake I configured parameters to use Qt-4.5.2 (no more, no less). After
> installing QGIS 1.3.0 the about menu tells me that QGIS have been built
> with Qt 4.3.4 and is running with Qt 4.3.4. I get also an error windows
> which tells that PyQT4 couldn't be loaded and python will not be loaded :(
> $ cmake . gives:
> -- Python libraries found
> -- Python bindings enabled
> -- Found Qt-Version 4.5.2
> All those issues seem linked each other. I mean I can't tell to QGIS to use
> Qt 4.5.2
> Any idea? thanks
> Y.
> Le Monday 28 September 2009 10:23:14 Marco Hugentobler, vous avez écrit :
> > Hi Yves
> > Probably a Qt designer version issue. What Qt version are you using?
> > Please try to open the file ui/qgsrasterterrainanalysisdialogbase.ui with
> > your Qt designer version and save it.
> > Regards,
> > Marco
> > Am Montag, 28. September 2009 10.03:14 schrieb Jacolin Yves:
> > > Hello,
> > > Last week-end I sent an email about an issue when building QGIS 1.3.0
> > > or trunk. I succeed to remove this problem after building correctly SIP
> > > and PyQt4.
> > > I have now a new problem on this file :
> > > raster_terrain_analysis/qgsrasterterrainanalysisdialog.h:21
> > > [ 77%] Built target oracleplugin
> > > [ 77%] Building CXX object
> > > src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir/
> > >qg sr asterterrainanalysisplugin.o In file included
> > > from
> > > /home/yjacolin/Documents/Logiciels/Sources/Geomatique/QGIS/qgis-1.3.0/s
> > >rc /p
> > > lugins/raster_terrain_analysis/qgsrasterterrainanalysisdialog.h:21,
> > > from
> > >rc /p
> > > lugins/raster_terrain_analysis/qgsrasterterrainanalysisplugin.cpp:27:
> > >rc /p
> > > lugins/raster_terrain_analysis/ui_qgsrasterterrainanalysisdialogbase.h:
> > >30
> > >: erreur: expected constructor, destructor, or type conversion before
> > > «class» make[2]: ***
> > > [src/plugins/raster_terrain_analysis/CMakeFiles/rasterterrainplugin.dir
> > >/q gs rasterterrainanalysisplugin.o] Erreur 1
> > > make[1]: ***
> > >/a ll ] Erreur 2
> > > make: *** [all] Erreur 2
> > > Does this new plugin need to do something before building?
> > > Thanks,
> > > Y.
Yves Jacolin
Ne demandez pas si vous pouvez contribuer, contribuez ! :)
http://softlibre.gloobe.org
