[Qgis-user] Can't compile current trunk - revision 11737
Ivan Mincik ivan.mincik at gmail.com
Wed Sep 30 13:42:24 PDT 2009
I am trying to compile Debian package from current trunk version of
QGIS,  revision 11737. All dependencies installed. Since now I didn't
have any problems to compile.
There was similar looking problem at the past, but according to Trac,
it should be fixed - https://trac.osgeo.org/qgis/ticket/1271   . I am
not sure if it is my problem or some problem suitable for bug tracker.
Any ideas ?
OS: Debian Lenny, x86, KDE
Compiling with:  dpkg-buildpackage  or debuild -us -uc
Error:
[ 42%] Building CXX object src/app/CMakeFiles/qgis.dir/qgsuniquevaluedialog.o
src/app/CMakeFiles/qgis.dir/qgsvectorlayerproperties.o
[ 42%] Building CXX object src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o
/home/ivo/storage/src/qgis/qgis_unstable/src/app/composer/qgscomposer.cpp:
In member function ‘void
QgsComposer::on_mActionExportAsSVG_triggered()’:
/home/ivo/storage/src/qgis/qgis_unstable/src/app/composer/qgscomposer.cpp:750:
error: ‘class QSvgGenerator’ has no member named ‘setTitle’
make[3]: *** [src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o] Error 1
make[3]: Leaving directory
`/home/ivo/storage/src/qgis/qgis_unstable/debian/build'
make[2]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
make[2]: Leaving directory
make[1]: *** [all] Error 2
make[1]: Leaving directory
make: *** [build-stamp] Error 2
dpkg-buildpackage: failure: debian/rules build gave error exit status 2
Thanks,
Ivan
