[Qgis-user] Can't compile current trunk - revision 11737
Marco Hugentobler marco at hugis.net
Wed Sep 30 13:58:39 PDT 2009
Hi Ivan
Seems like QSvgGenerator::setTitle is only available in newer Qt versions.
What version are you using?
Regards,
Marco
Am Mittwoch, 30. September 2009 22.42:24 schrieb Ivan Mincik:
> I am trying to compile Debian package from current trunk version of
> QGIS,  revision 11737. All dependencies installed. Since now I didn't
> have any problems to compile.
> There was similar looking problem at the past, but according to Trac,
> it should be fixed - https://trac.osgeo.org/qgis/ticket/1271   . I am
> not sure if it is my problem or some problem suitable for bug tracker.
> Any ideas ?
> OS: Debian Lenny, x86, KDE
> Compiling with:  dpkg-buildpackage  or debuild -us -uc
> Error:
> [ 42%] Building CXX object
> src/app/CMakeFiles/qgis.dir/qgsuniquevaluedialog.o [ 42%] Building CXX
> object
> src/app/CMakeFiles/qgis.dir/qgsvectorlayerproperties.o
> src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o
> /home/ivo/storage/src/qgis/qgis_unstable/src/app/composer/qgscomposer.cpp:
> In member function ‘void
> QgsComposer::on_mActionExportAsSVG_triggered()’:
> /home/ivo/storage/src/qgis/qgis_unstable/src/app/composer/qgscomposer.cpp:7
>50: error: ‘class QSvgGenerator’ has no member named ‘setTitle’
> make[3]: *** [src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o] Error 1
> make[3]: Leaving directory
> `/home/ivo/storage/src/qgis/qgis_unstable/debian/build'
> make[2]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
> make[2]: Leaving directory
> make[1]: *** [all] Error 2
> make[1]: Leaving directory
> make: *** [build-stamp] Error 2
> dpkg-buildpackage: failure: debian/rules build gave error exit status 2
> Thanks,
> Ivan
> Qgis-user mailing list
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Honrainweg 5
CH-8038 Zürich
marco at hugis.net
http://homepage.hispeed.ch/hugis/
