[Qgis-user] Can't compile current trunk - revision 11737
Marco Hugentobler marco at hugis.net
Wed Sep 30 14:06:26 PDT 2009
Ok, the doc says it's only available from 4.5. on. So I'm going to remove that
line in the next commit.
Regards,
Marco
Am Mittwoch, 30. September 2009 22.58:39 schrieb Marco Hugentobler:
> Hi Ivan
> Seems like QSvgGenerator::setTitle is only available in newer Qt versions.
> What version are you using?
> Regards,
> Marco
> Am Mittwoch, 30. September 2009 22.42:24 schrieb Ivan Mincik:
> > I am trying to compile Debian package from current trunk version of
> > QGIS,  revision 11737. All dependencies installed. Since now I didn't
> > have any problems to compile.
> > There was similar looking problem at the past, but according to Trac,
> > it should be fixed - https://trac.osgeo.org/qgis/ticket/1271   . I am
> > not sure if it is my problem or some problem suitable for bug tracker.
> > Any ideas ?
> > OS: Debian Lenny, x86, KDE
> > Compiling with:  dpkg-buildpackage  or debuild -us -uc
> > Error:
> > [ 42%] Building CXX object
> > src/app/CMakeFiles/qgis.dir/qgsuniquevaluedialog.o [ 42%] Building CXX
> > object
> > src/app/CMakeFiles/qgis.dir/qgsvectorlayerproperties.o
> > src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o
> > /home/ivo/storage/src/qgis/qgis_unstable/src/app/composer/qgscomposer.cpp
> >: In member function ‘void
> > QgsComposer::on_mActionExportAsSVG_triggered()’:
> >:7 50: error: ‘class QSvgGenerator’ has no member named ‘setTitle’
> > make[3]: *** [src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o] Error 1
> > make[3]: Leaving directory
> > `/home/ivo/storage/src/qgis/qgis_unstable/debian/build'
> > make[2]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
> > make[2]: Leaving directory
> > make[1]: *** [all] Error 2
> > make[1]: Leaving directory
> > make: *** [build-stamp] Error 2
> > dpkg-buildpackage: failure: debian/rules build gave error exit status 2
> > Thanks,
> > Ivan
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Honrainweg 5
CH-8038 Zürich
marco at hugis.net
http://homepage.hispeed.ch/hugis/
