Fwd: [Qgis-user] Can't compile current trunk - revision 11737
Ivan Mincik
ivan.mincik at gmail.com
Wed Sep 30 14:11:13 PDT 2009
On Wed, Sep 30, 2009 at 10:58 PM, Marco Hugentobler <marco at hugis.net> wrote:
> Hi Ivan
> Seems like QSvgGenerator::setTitle is only available in newer Qt versions.
> What version are you using?
Thanks. I am using Qt 4.4.3 which is in Debian Lenny repository. Qt
docs says, that this function was introduced in Qt 4.5, so current
stable Debian will be out of the game. Is it really needed to use such
new Qt versions ?
> Regards,
> Marco
> Am Mittwoch, 30. September 2009 22.42:24 schrieb Ivan Mincik:
>> I am trying to compile Debian package from current trunk version of
>> QGIS, revision 11737. All dependencies installed. Since now I didn't
>> have any problems to compile.
>> There was similar looking problem at the past, but according to Trac,
>> it should be fixed - https://trac.osgeo.org/qgis/ticket/1271 . I am
>> not sure if it is my problem or some problem suitable for bug tracker.
>> Any ideas ?
>> OS: Debian Lenny, x86, KDE
>> Compiling with: dpkg-buildpackage or debuild -us -uc
>> Error:
>> [ 42%] Building CXX object
>> src/app/CMakeFiles/qgis.dir/qgsuniquevaluedialog.o [ 42%] Building CXX
>> object
>> src/app/CMakeFiles/qgis.dir/qgsvectorlayerproperties.o
>> src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o
>> /home/ivo/storage/src/qgis/qgis_unstable/src/app/composer/qgscomposer.cpp:
>> In member function ‘void
>> QgsComposer::on_mActionExportAsSVG_triggered()’:
>> /home/ivo/storage/src/qgis/qgis_unstable/src/app/composer/qgscomposer.cpp:7
>>50: error: ‘class QSvgGenerator’ has no member named ‘setTitle’
>> make[3]: *** [src/app/CMakeFiles/qgis.dir/composer/qgscomposer.o] Error 1
>> make[3]: Leaving directory
>> `/home/ivo/storage/src/qgis/qgis_unstable/debian/build'
>> make[2]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
>> make[2]: Leaving directory
>> make[1]: *** [all] Error 2
>> make[1]: Leaving directory
>> make: *** [build-stamp] Error 2
>> dpkg-buildpackage: failure: debian/rules build gave error exit status 2
>> Thanks,
>> Ivan
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr. Marco Hugentobler
> HUGIS - GIS programming and consulting
> Honrainweg 5
> CH-8038 Zürich
> marco at hugis.net
> http://homepage.hispeed.ch/hugis/
