[Qgis-user] RE: Grass error in Quantum GIS 1.4.0 from Kcubeconsulting
Kumaran Narayanaswamy
kumaran.narayanaswamy at kcubeconsulting.com
Sat Apr 3 08:20:44 PDT 2010
Agus,
Can you let us know if the error exists in OSGEO4W version as we have just
built the version from OSGEO4W binaries?
Regards
Kumaran
-----Original Message-----
From: Agustin Lobo [mailto:alobolistas at gmail.com]
Sent: Saturday, April 03, 2010 3:46 PM
To: Kumaran Narayanaswamy; qgis-user
Subject: Grass error in Quantum GIS 1.4.0 from Kcubeconsulting
Kumaran,
We've found an error at setting the grass default region:
we select New Mapset and when we get to the Default GRASS Region
panel and select the tab "Set Current Qgis extent", the N and S
coordinates are correct (coincident with the display) but the
W and E coordinates are wrong (defining a much larger region).
We use a UTM projection.
This error is not present in the linux version of Qgis 1.4.0, which sets the
same N and S limits but sets the correct W and E limits.
Could anybody check if this error is also present in the
osgeo4w version of Qgis 1.4.0 ?
Thanks
Agus
