[Qgis-user] proj file and QGIS
Carson Farmer carson.farmer at gmail.com
Tue Apr 13 08:05:33 PDT 2010
it's possible you prj file isn't getting read properly? what software
did you use to create the prj file?
you can check the properties of the layer to see if your prj info is
correctly specified, and if not, change it manually there... you could
also then use the define projection tool from the vector tools to
properly specify your prj...
Carson
On Tue, Apr 13, 2010 at 3:42 PM, Yves Jacolin <yjacolin at free.fr> wrote:
> Le mardi 13 avril 2010 16:38:39, Micha Silver a écrit :
>> I'm not sure I understand. What did you expect to happen?
>> With OTF enabled, when you open a vector which is projected in some
>> different CRS, the it should appear reprojected into the project CRS.
> Hi Micha,
> When I open a file in projection XXX in a QGIS project with a projection YY +
> OTF enabled I would like that QGIS read the prj file of my shapefile and
> reprojected it correctly.
> My tests showed that the prj file is not read/used by QGIS.
> Am I wrong ? Is it a known limitation depending the prj file?
> Regards,
> Y.
> Yves Jacolin
> http://yjacolin.gloobe.org
> Qgis-user mailing list
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation
National University of Ireland, Maynooth,
http://www.carsonfarmer.com/
