[Qgis-user] Mobile GIS
Noli Sicad nsicad at gmail.com
Tue Apr 20 14:33:00 PDT 2010
Hi Phillip,
Thanks for sharing your project and ideas.
Have you tried this app.
https://confluence.prodevelop.es/display/GVMN/Home
Probably you can borrow some of their codes to incorporate to what you
have started. It is GPL project as as well. I think there is no edit
function in the map viewer.
Regards,
Noli
On 4/21/10, Philipp Auersperg-Castell <phil at bluedynamics.com> wrote:
> IT depends what you need from the mobile GIS application,I am
> currently poking around with android, Qgis and MapServer for forrestry
> mapping.
> I used Qgis to develop a forest map for my forest enterprise, with
> PostGis as backend.
> Recently Ive bought my first Android smartphone with GPS integrated
> and in consequence there came up the wish to display my forest map in
> GoogleMaps (with the satellite image as background) and the ability to
> mark points or areas by GPS and upload them into the GIS.
> So I typed 'gis' and 'map' and similar terms into Android Market
> (=AppStore in the Android world) and found nothing useful except apps
> for geocaching, hiking, mountainbiking and the like, but
> nothing that would fit my needs.
> As a consequence I started experimenting with the Android SDK and
> found out that it is not too much work to use the MapView shipping
> with the SDK to display stuff on top of the google satellite image.
> With the help of JTS (a java library for geo stuff,
> http://www.vividsolutions.com/jts/jtshome.htm)
>   it was less than 100 lines of code to display polygon layers as
> overlay into the MapView. Most of the work was to get initially
> familiar with Android SDK and its philosophy, and with its integration
> to eclipse it seems quite handy to me.
> The next Problem is how to get my maps from Qgis/Postgis to my phone,
> there I decided for an online solution with MapServer as backend. QGis
> has MapServerExport as plugin, so its no big deal to  export a QGIS
> project to MapServer. Then I wrote an xmlrpc server (around 150 lines
> of python code including coordinate transformation) which deploys the
> layer features in the WKT format, that I parse on my handheld with the
> help of JTS library and the module mentioned above displays it on my
> MapView.
> I also wrote some code to capture coordinates (points and areas) with
> GPS and are currently working on uploading them into the GIS server.
> My software can even mark remote points using the handheld's camera
> and the device's internal compass for the direction. I then just have
> to manually enter the distance read from a laser distance meter and
> have my point location.
> All that is by far not production ready but serves for me as a proof
> of concept that I can display my map online from my server on my
> android phone and be able to digitize features with GPS.
> If anybody is working on such a beast please let me know if you are
> interested in doing some work together....
> regards
> Philipp
