[Qgis-user] Mobile GIS
Miguel Montesinos mmontesinos at prodevelop.es
Wed Apr 21 03:00:38 PDT 2010
Hi Phillip and Noli,
We have developed the application Phillip points out. It doen't support
those features so far, but if you like to use it as a base, we are ready
to collaborate in order to support the creation of geometries (point,
polyline, polygon) from the GPS (or hand-based), or some other vector
capabilitites.
I've recently acquired my third Android phone, and I'm sure that Android
projection is going to be really impressive (it's right now, as a matter
of fact).
It will be great to extend the community of users and developers of this
application.
Regards,
Miguel Montesinos
> -----Mensaje original-----
> De: qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org]
> En nombre de Noli Sicad
> Enviado el: martes, 20 de abril de 2010 23:33
> Para: Philipp Auersperg-Castell
> CC: qgis-user
> Asunto: Re: [Qgis-user] Mobile GIS
> Hi Phillip,
> Thanks for sharing your project and ideas.
> Have you tried this app.
> https://confluence.prodevelop.es/display/GVMN/Home
> Probably you can borrow some of their codes to incorporate to what you
> have started. It is GPL project as as well. I think there is no edit
> function in the map viewer.
> Regards,
> Noli
> On 4/21/10, Philipp Auersperg-Castell <phil at bluedynamics.com> wrote:
> > IT depends what you need from the mobile GIS application,I am
> > currently poking around with android, Qgis and MapServer for
forrestry
> > mapping.
> > I used Qgis to develop a forest map for my forest enterprise, with
> > PostGis as backend.
> > Recently Ive bought my first Android smartphone with GPS integrated
> > and in consequence there came up the wish to display my forest map
in
> > GoogleMaps (with the satellite image as background) and the ability
to
> > mark points or areas by GPS and upload them into the GIS.
> > So I typed 'gis' and 'map' and similar terms into Android Market
> > (=AppStore in the Android world) and found nothing useful except
apps
> > for geocaching, hiking, mountainbiking and the like, but
> > nothing that would fit my needs.
> > As a consequence I started experimenting with the Android SDK and
> > found out that it is not too much work to use the MapView shipping
> > with the SDK to display stuff on top of the google satellite image.
> > With the help of JTS (a java library for geo stuff,
> > http://www.vividsolutions.com/jts/jtshome.htm)
> >   it was less than 100 lines of code to display polygon layers as
> > overlay into the MapView. Most of the work was to get initially
> > familiar with Android SDK and its philosophy, and with its
integration
> > to eclipse it seems quite handy to me.
> > The next Problem is how to get my maps from Qgis/Postgis to my
phone,
> > there I decided for an online solution with MapServer as backend.
QGis
> > has MapServerExport as plugin, so its no big deal to  export a QGIS
> > project to MapServer. Then I wrote an xmlrpc server (around 150
lines
> > of python code including coordinate transformation) which deploys
the
> > layer features in the WKT format, that I parse on my handheld with
the
> > help of JTS library and the module mentioned above displays it on my
> > MapView.
> > I also wrote some code to capture coordinates (points and areas)
with
> > GPS and are currently working on uploading them into the GIS server.
> > My software can even mark remote points using the handheld's camera
> > and the device's internal compass for the direction. I then just
have
> > to manually enter the distance read from a laser distance meter and
> > have my point location.
> > All that is by far not production ready but serves for me as a proof
> > of concept that I can display my map online from my server on my
> > android phone and be able to digitize features with GPS.
> > If anybody is working on such a beast please let me know if you are
> > interested in doing some work together....
> > regards
> > Philipp
> Qgis-user mailing list
