[Qgis-user] empty map composer window on reopen
Micha Silver micha at arava.co.il
Tue Apr 20 23:40:18 PDT 2010
On 21/04/2010 01:20, Goyo wrote:
> El lun, 19-04-2010 a las 16:18 +0300, Micha Silver escribió:
>> I find the following behavior on QGIS 1.4, from the UbuntuGIS repo:
>> I finish and save a project with a map designed in the composer window.
>> After I close QGIS and then reopen the project, it opens and immediately
>> an *empty* composer window opens on top. This window cannot be closed,
>> only minimized.  After minimizing, I can run the Map Composer manager
>> and delete that composer window. (But then all the map design gets lost...)
>> Has anyone else seen this?
> I can reproduce this.
> But you don't have to lose the map design, just show it instead of
> deleting.
Ah, I never thought to try that. Thanks.
Still the bug needs to be dealt with. Do you know if this issue is
entered into trac?
> Goyo
> This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
