[Qgis-user] empty map composer window on reopen
Goyo goyodiaz at gmail.com
Tue Apr 20 15:20:54 PDT 2010
El lun, 19-04-2010 a las 16:18 +0300, Micha Silver escribió:
> I find the following behavior on QGIS 1.4, from the UbuntuGIS repo:
> I finish and save a project with a map designed in the composer window.
> After I close QGIS and then reopen the project, it opens and immediately
> an *empty* composer window opens on top. This window cannot be closed,
> only minimized.  After minimizing, I can run the Map Composer manager
> and delete that composer window. (But then all the map design gets lost...)
> Has anyone else seen this?
I can reproduce this.
But you don't have to lose the map design, just show it instead of
deleting.
Goyo
