[Qgis-user] Postgis manager can't load shapefile
Lionel Roubeyrie lionel.roubeyrie at gmail.com
Thu Apr 22 04:56:38 PDT 2010
Effectively,
I forgot to copy shp2pgsql to the bin PATH...
thanks for the help
2010/4/22 Bernhard Ströbl <Bernhard.Stroebl at jena.de>:
> I had the same error a while ago exporting to a remote PostGIS DB. If I
> recall correctly postgis manager assumes a PostGIS-Installation on the same
> machine and thus expects the presence of the loader (shp2pgsql). If you have
> PostgreSQL/PostGIS installed locally point your path variable to where
> shp2pgsql resides otherwise install it (worked for me on WinXP) or go with
> SPIT.
> hope this helps
> Bernhard
> Lionel Roubeyrie schrieb:
>> Hi all,
>> I try to import some shapefiles to postgresql (8.4 from ubuntu repo,
>> postgis 1.5.1 self-compiled) using the postgis manager plugin, but it
>> always fails with no explicit message :
>> Message :
>> Filename : None
>> where SPIT goes well...
>> An idea?
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
Lionel Roubeyrie
http://youarealegend.blogspot.com
