[Qgis-user] Postgis manager can't load shapefile
Bernhard Ströbl Bernhard.Stroebl at jena.de
Thu Apr 22 04:37:09 PDT 2010
I had the same error a while ago exporting to a remote PostGIS DB. If I
recall correctly postgis manager assumes a PostGIS-Installation on the
same machine and thus expects the presence of the loader (shp2pgsql). If
you have PostgreSQL/PostGIS installed locally point your path variable
to where shp2pgsql resides otherwise install it (worked for me on WinXP)
or go with SPIT.
hope this helps
Bernhard
Lionel Roubeyrie schrieb:
> Hi all,
> I try to import some shapefiles to postgresql (8.4 from ubuntu repo,
> postgis 1.5.1 self-compiled) using the postgis manager plugin, but it
> always fails with no explicit message :
> Message :
> Filename : None
> where SPIT goes well...
> An idea?
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
