[Qgis-user] Re: compiled qgis1.5 but have no Python support
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Mon Aug 2 03:01:46 PDT 2010
Hi Harry
Please keep this mail on the qgis-user list, so that you may get
better help from more people ;)
What is the error message that you are getting when compiling? I'm not
really sure what I was missing, as I installed a lot of packages. I
guess I was missing some of the development packages (those that
usually end with -dev)
On Mon, Aug 2, 2010 at 2:01 AM, Harry G McGavran Jr <w5pny at arrl.net> wrote:
> On July 25, 2010 Ricardo Filipe Soares Garcia da wrote:
>>Hello
>>Problem solved, I was just missing some dependencies. I re-read the
>>INSTALL document that comes with the source and everything was
>>cleared. Sorry for the noise
>>On Sun, Jul 25, 2010 at 10:40 AM, Ricardo Filipe Soares Garcia da
>><ricardo.garcia.silva at gmail.com> wrote:
>>> Hello all
>>> I am using Kubuntu 10.04. I was using Qgis 1.4 from the ubuntugis ppa,
>>> which worked fine.
>>> After compiling the new Qgis 1.5, python support is no longer enabled.
>>> I am getting the following error when I start Qgis:
>>> Couldn't load PyQGIS.
>>> Python support will be disabled.
> I'm having the same problem, but when I check INSTALL and compare it
> with the dependencies I need, mine look fine.  Which dependency(s)
> do you need to upate????
>      Harry
> Harry G. McGavran, Jr.
> E-mail: w5pny at arrl.net
___________________________ ___ __
Ricardo Garcia Silva
