[Qgis-user] Re: compiled qgis1.5 but have no Python support
maning sambale emmanuel.sambale at gmail.com
Mon Aug 2 03:12:28 PDT 2010
Using:
sudo apt-get install qgis
Doesn't completely upgrade Python support.  Try:
sudo apt-get install python-qgis python-qgis-common
On Mon, Aug 2, 2010 at 6:01 PM, Ricardo Filipe Soares Garcia da
<ricardo.garcia.silva at gmail.com> wrote:
> Hi Harry
> Please keep this mail on the qgis-user list, so that you may get
> better help from more people ;)
> What is the error message that you are getting when compiling? I'm not
> really sure what I was missing, as I installed a lot of packages. I
> guess I was missing some of the development packages (those that
> usually end with -dev)
> On Mon, Aug 2, 2010 at 2:01 AM, Harry G McGavran Jr <w5pny at arrl.net> wrote:
>> On July 25, 2010 Ricardo Filipe Soares Garcia da wrote:
>>>Hello
>>>Problem solved, I was just missing some dependencies. I re-read the
>>>INSTALL document that comes with the source and everything was
>>>cleared. Sorry for the noise
>>>On Sun, Jul 25, 2010 at 10:40 AM, Ricardo Filipe Soares Garcia da
>>>> Hello all
>>>> I am using Kubuntu 10.04. I was using Qgis 1.4 from the ubuntugis ppa,
>>>> which worked fine.
>>>> After compiling the new Qgis 1.5, python support is no longer enabled.
>>>> I am getting the following error when I start Qgis:
>>>> Couldn't load PyQGIS.
>>>> Python support will be disabled.
>> I'm having the same problem, but when I check INSTALL and compare it
>> with the dependencies I need, mine look fine.  Which dependency(s)
>> do you need to upate????
>>      Harry
>> Harry G. McGavran, Jr.
>> E-mail: w5pny at arrl.net
> ___________________________ ___ __
> Ricardo Garcia Silva
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
