[Qgis-user] Re: compiled qgis1.5 but have no Python support
Harry G McGavran Jr w5pny at arrl.net
Mon Aug 2 11:03:29 PDT 2010
I downloaded the debian python-qgis and python-qgis-common
and compared the package contents to what I have, and it
seems to correspond, although the debian packages seem
to be for QGIS-1.4.0.
I'm using python 2.5.2 and the error message I get
with QGIS-1.5.0 is:
Couldn't load PyQGIS.
Python support will be disabled.
  File "", line 1, in
ImportError: dynamic module does not define init function (initcore)
On Mon, 02 Aug 2010 09:17:26 -0600 Harry G McGavran Jr wrote:
> This seems likely to fix the problem -- but -- I'm still
> using Ubuntu Hardy and python-qgis and python-qgis-common
> are not packages on the usual Hardy repositories.  What python
> components need upgrading??? I've rebuilt other non-Hardy upgradable
> components such as gdal and geos in /usr/local for the purpose of upgrading
> QGIS.
> On Mon, 2 Aug 2010 18:12:28 +0800 maning sambale wrote:
> > Using:
> > sudo apt-get install qgis
> > Doesn't completely upgrade Python support.  Try:
> > sudo apt-get install python-qgis python-qgis-common
> > On Mon, Aug 2, 2010 at 6:01 PM, Ricardo Filipe Soares Garcia da
> > <ricardo.garcia.silva at gmail.com> wrote:
> > > Hi Harry
> > > Please keep this mail on the qgis-user list, so that you may get
> > > better help from more people ;)
> > > What is the error message that you are getting when compiling? I'm not
> > > really sure what I was missing, as I installed a lot of packages. I
> > > guess I was missing some of the development packages (those that
> > > usually end with -dev)
> > > On Mon, Aug 2, 2010 at 2:01 AM, Harry G McGavran Jr <w5pny at arrl.net> wrot
> > e:
> > >> On July 25, 2010 Ricardo Filipe Soares Garcia da wrote:
> > >>>Hello
> > >>>Problem solved, I was just missing some dependencies. I re-read the
> > >>>INSTALL document that comes with the source and everything was
> > >>>cleared. Sorry for the noise
> > >>>On Sun, Jul 25, 2010 at 10:40 AM, Ricardo Filipe Soares Garcia da
> > >>>> Hello all
> > >>>> I am using Kubuntu 10.04. I was using Qgis 1.4 from the ubuntugis ppa,
> > >>>> which worked fine.
> > >>>> After compiling the new Qgis 1.5, python support is no longer enabled.
> > >>>> I am getting the following error when I start Qgis:
> > >> =C2=A0 =C2=A0.
> > >> =C2=A0 =C2=A0.
> > >> =C2=A0 =C2=A0.
> > >> I'm having the same problem, but when I check INSTALL and compare it
> > >> with the dependencies I need, mine look fine. =C2=A0Which dependency(s)
> > >> do you need to upate????
> > >> =C2=A0 =C2=A0 =C2=A0Harry
> > >> Harry G. McGavran, Jr.
> > >> E-mail: w5pny at arrl.net
> > > ___________________________ ___ __
> > > Ricardo Garcia Silva
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > --=20
> > cheers,
> > maning
> > "Freedom is still the most radical idea of all" -N.Branden
> > wiki: http://esambale.wikispaces.com/
> > blog: http://epsg4253.wordpress.com/
