[Qgis-user] management tables
Dario darioqn at yahoo.com.br
Wed Aug 4 06:19:55 PDT 2010
Hello friends list, I would like to know:
You can make a union of tables in qgis?
it is possible to "join" table in qgis?
How to insert field "hiperlink" in table in qgis?
Thank you.
De: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
Para: qgis-user at lists.osgeo.org
Enviadas: Quarta-feira, 4 de Agosto de 2010 8:01:03
Assunto: Qgis-user Digest, Vol 54, Issue 5
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
   1. Re: Qgis-user Digest, Vol 54, Issue 4 (Gary Smith)
   2. check Qgis version (Brad Nesom)
   3. postgis problem 1.5 (Brad Nesom)
   4. GeoWebCache in QGIS 1.5... (Nicolas Gignac)
   5. Re: GeoWebCache in QGIS 1.5... (J?rgen E. Fischer)
   6. Compile problem? (M?ri Cedric)
   7. Installing QGIS 1.5 on Debian Lenny (Niccolo Rigacci)
   8. Re: Compile problem? (J?rgen E. Fischer)
   9. AW: [Qgis-user] Compile problem? (M?ri Cedric)
Message: 1
Date: Tue, 03 Aug 2010 19:25:01 +0200
Subject: [Qgis-user] Re: Qgis-user Digest, Vol 54, Issue 4
To: qgis-user at lists.osgeo.org
Message-ID: <4C5850ED.3020403 at gmail.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Nicollo,
I get a segmentation fault. This occurs immediately the "Starting
Python" message is displayed on the Splash screen.
Also, there also appears to be a dependency problem with the grass plugin.
I get the following message when I try to upgrade the
"qgis-grass-plugin-common" package:
"qgis-plugin-grass-common:
  Depends: qgis-plugin-grass but it is not going to be installed"
The "qgis-plugin-grass" package does not have a 1.5 candidate.
I hope that you can resolve this shortly as I am now without a working
QGIS :-( I could revert to 1.4 but I am really keen to review 1.5.
Thanks all!
Gary
> Today's Topics:
>     1. Problem with WMS-C (Dominik Helle)
>     2. eVis: Making connections permanent? (Timmie)
>     3. QGIS version 1.5 packaged for Debian Lenny (Niccolo Rigacci)
>     4. Re: Re: Release version 1.5 (Giovanni Manghi)
>     5. Re: Re: compiled qgis1.5 but have no Python support
>        (Harry G McGavran Jr)
>     6. Re: Problem with WMS-C (Jürgen E. Fischer)
>     7. Re: Error upgrading to 1.5 Ubuntu 10.04 (NoOp)
>     8. Re: Problem with WMS-C (Dominik Helle)
>     9. MRsid/ ECW (Doug Lane)
> Message: 1
> Date: Mon, 2 Aug 2010 17:48:46 +0200
> From: Dominik Helle<liste at der-helle.de>
> Subject: [Qgis-user] Problem with WMS-C
> Message-ID:<33AEDAE6-F89D-4275-B06B-805E4C360C16 at der-helle.de>
> Content-Type: text/plain; charset=us-ascii
> Hey list,
> i was pleased to read that QGIS now supports WMS-C.
> So I tried it, but I had unfortunately no success.
> I used a WMS that supports WMS-C and added it with the option tiled=true to
>QGIS.
> (e.g. http://localhost:8181/service?TILED=true - as it is specified in the WMS
>Tiling Recommendation
>http://wiki.osgeo.org/wiki/WMS_Tiling_Client_Recommendation )
> QGIS add the WMS, and show a map. But QGIS only send one request to the WMS. So
>it is like using a normal WMS and not a WMS-C. Is there a trick how i can use a
>WMS-C with QGIS?
> Thanks in advance.
> Best regards,
> Dominik
> Message: 2
> Date: Mon, 2 Aug 2010 16:20:01 +0000 (UTC)
> From: Timmie<timmichelsen at gmx-topmail.de>
> Subject: [Qgis-user] eVis: Making connections permanent?
> Message-ID:<loom.20100802T181618-289 at post.gmane.org>
> Dear all,
> I am just discovering eVis.
> Really a great tool visualising points of interest.
> Is there a option to make a ODBC connection to -- for example -- MS Excel
> permanent so that I do not need to reconnect after the project is re-opened?
> Currently, when I save a project with an event layer and re-open it, I am
asked
> to identify a missing layer.
> I welcome any help.
> Best regards,
> Timmie
> Message: 3
> Date: Mon, 2 Aug 2010 18:45:59 +0200
> From: Niccolo Rigacci<niccolo at rigacci.org>
> Subject: [Qgis-user] QGIS version 1.5 packaged for Debian Lenny
> Message-ID:<20100802164559.GA19303 at rigacci.org>
> On Sun, Aug 01, 2010 at 06:43:47PM +0200, Gary Smith wrote:
>> It doesn't look like the Debian repository listed in the download page
>> has 1.5 available. Anywhere else I can get it?
> Today I uploaded QGIS 1.5 packaged for Debian Lenny (i386 and
> amd64 architectures) to the **unofficial** repository:
> deb http://debian.gfoss.it/ lenny main
> Please report any problem with the packaging to me, not to the
> innocent official Debian mantainers.
Message: 2
Date: Tue, 3 Aug 2010 12:57:19 -0500
Subject: [Qgis-user] check Qgis version
To: qgis-user <qgis-user at lists.osgeo.org>
Message-ID:
    <AANLkTim8MFbuzb0fi2yQMX2Uhm=O9Zvi2Zf5nVJkgXv- at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
version 1.6 r13999
In the check qgis version dialog under the help pulldown it says the
following.
The current released version of QGIS is 1.4.0 "Enceladus".
The development version (1.5.0 AKA Trunk) contains a number of bug fixes and
enhancements
Details on changes can be found by examining the Timeline in Trac at
http://trac.osgeo.org/qgis.
probably should be updated huh?
URL:
http://lists.osgeo.org/pipermail/qgis-user/attachments/20100803/4e001d49/attachment-0001.html
Message: 3
Date: Tue, 3 Aug 2010 13:35:49 -0500
Subject: [Qgis-user] postgis problem 1.5
Message-ID:
    <AANLkTinTQDu3nGzgi+8iu_hF4qE0FqWr22GoS9cAb-FY at mail.gmail.com>
Having a problem connecting to postgis. I get successful verification on the
test connection but inval privileges when I use connect. However I just
opened 1.6 and connected successully to the same ddataset. Anyone verify
this?
URL:
http://lists.osgeo.org/pipermail/qgis-user/attachments/20100803/93d4b67b/attachment-0001.html
Message: 4
Date: Tue, 3 Aug 2010 16:19:57 -0400
Subject: [Qgis-user] GeoWebCache in QGIS 1.5...
Message-ID:
    <AANLkTikuDm6qnG7AhUf-iK7BqB1Zb7AYq3Ef8f0+QtYi at mail.gmail.com>
I have downloaded the new version of QGIS 1.5 Tehtys and I try the new
feature WMS-C reader of tile service, such as Tilecache.
However, I was not able to connected properly to GeoWebCache tile service
such as this one:
http://maps.opengeo.org/geowebcache/service/wms?request=GetCapabilities
1- Does this functionnality is mature enough to read GeoWebCache or any
other tileservice (Tilecache, etc.)? I have a message saying "Http request
failed, does not understand the server response"...
2- Does this functionnality is supposed to be mature enough to view/read
tile image as fast as OpenLayers? My tilecache in QGIS takes way more time
to view the same tileservice in OpenLayers.
3- Any docs available to understand how this feature works?
By the way, it is a very good feature! Congrats to QGIS dev team!
Cheers,
Nicolas
URL:
http://lists.osgeo.org/pipermail/qgis-user/attachments/20100803/ac618fa1/attachment-0001.html
Message: 5
Date: Tue, 3 Aug 2010 23:32:49 +0200
Subject: Re: [Qgis-user] GeoWebCache in QGIS 1.5...
Message-ID: <20100803213249.GA28551 at norbit.de>
Content-Type: text/plain; charset=iso-8859-1
Hi Nicolas,
>    such as this one:
>    [1]http://maps.opengeo.org/geowebcache/service/wms?request=GetCapabilities
Works fine for me as WMS, but it doesn't advertise any tilesets.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden              http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Message: 6
Date: Wed, 4 Aug 2010 12:19:31 +0200
Subject: [Qgis-user] Compile problem?
Message-ID:
    <1399532863.60141280917171416.JavaMail.root at srsofaioi13477.ktso.ch>
Hi all
I just compiled r14004 on RedHat-Linux. Everything seems to go fine, but when I
now start the new qgis, it says
Warning: Couldn't load Python support library: Cannot load library
/lib/qgispython: (/lib/libqgispython.so: Kann die Shared-Object-Datei nicht
öffnen: Datei oder Verzeichnis nicht gefunden)
(the german reads: Cannot open shared object file: File or directory not found)
I'm using a CMAKE_INSTALL_PREFIX which points to /usr/local/foo
In fact /lib/libqgispython.so doesn't exist, but with the prefix I'm expecting
the so-file in /usr/local/foo/lib. And that's where I found libqgispython.so
which links to libqgispython.so.1.6.0 in the same directory.
I did also a make clean, but the same result.
Has anybody a hint for me, what I'm missing? Do I have some misconfiguration in
my ccmake or what else could be wrong?
Regards
Cédric
mit freundlichen Grüssen
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon: +41 (0)32 627 24 75
Telefax: +41 (0)32 627 22 14
mailto:cedric.moeri at bd.so.ch
http://www.agi.so.ch
Message: 7
Date: Wed, 4 Aug 2010 12:22:13 +0200
Subject: [Qgis-user] Installing QGIS 1.5 on Debian Lenny
To: Gary Smith <gary.smith.rsa at gmail.com>
Cc: qgis-user at lists.osgeo.org
Message-ID: <20100804102213.GA7452 at rigacci.org>
On Tue, Aug 03, 2010 at 07:25:01PM +0200, Gary Smith wrote:
> Nicollo,
Check all the old packages/libraries you have installed and
remove them manually:
dpk --list | grep qgis
dpkg --purge <package_name> <package_name> ...
Then re-do the apt-get install.
Niccolo Rigacci
Firenze - Italy
Message: 8
Date: Wed, 4 Aug 2010 12:36:25 +0200
Subject: Re: [Qgis-user] Compile problem?
Message-ID: <20100804103625.GC21626 at norbit.de>
Hi Cédric,
> I now start the new qgis, it says
> öffnen: Datei oder Verzeichnis nicht gefunden) (the german reads: Cannot open
Do you have old QGIS libraries or headers around?
Jürgen
Message: 9
Date: Wed, 4 Aug 2010 13:00:58 +0200
Subject: AW: [Qgis-user] Compile problem?
Message-ID:
    <523422441.63801280919658812.JavaMail.root at srsofaioi13477.ktso.ch>
Hi Jürgen
in /usr/local/foo/lib are also libs from a former 1.5.0. On the same machine are
also two other installations of qgis (r13851) both also with prefixes. They work
properly. So yes, there is stuff from other/older installations. Is that what
you mean? Any idea how to identfiy the 'bad' libs or headers?
regards/beste Grüsse
Cédric
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Rötistrasse 4
4501 Solothurn
----- Originalnachricht -----
Von: "Jürgen E. Fischer" <jef at norbit.de>
Gesendet: Mit, 4.8.2010 12:36
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Compile problem?
Hi Cédric,
Jürgen
Qgis-user at lists.osgeo.org
End of Qgis-user Digest, Vol 54, Issue 5
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100804/1006acbd/attachment.html>
